Multi-Fit Parts and Accessories For those Parts and Accessories that fit more than one model of Harley Davidson.
Cams & cam parts
Old 04-16-2010, 12:55 PM
jorswift's Avatar
jorswift
jorswift is offline
Default Cams & cam parts
For sale I have some parts brand new I bought from dealer to do a cam swap. Well, turns out I did not have to do the cam swap. So for sale I have
Brand new still in package
1 11286 O-ring @ .76
1 11301 O-ring @ .76
1 11293 O-ring @ .76
2 11031 Retaining Ring @ 1.60
1 39964-99A Chain Tensioner, secondary @ 52.12
1 39954-99A Chanin Tensioner, Primary @ 52.12
1 35060-00 Bearing, Retention plate @ .52
1 601 Roll Pin @ .32
Also have a used set of SE203 Cams with less than 5000 miles @ 125.00
So will take $215.00 for it complete plus shipping. I have to pay 10% restocking fee to return parts at dealer. Thanks.
SE-203 Cam Kit-Screamin’ Eagle® for Twin Cam 88®-equipped models.
Model Family: Dyna Touring
Weight: 5 lbs.
Description
Performance cam kit designed to provide exceptional low and mid-range torque. These cams are also used in the S.E. Stage II EFI Kits. For Race Application.Performance Cams for Twin Cam 88™ Equipped models. Kits include front and rear cams. Splined rear cam is included for exceptional load handling capability. Gaskets and bearings not included. Dealer installation is recommended, and special tools are required for proper installation. Please purchase Cam Installation Kit P/N 17045-99A which contains all required gaskets, bearings, and seals for proper installation. For proper cam gear spacing, Cam Spacer Kit P/N 25938-00 is recommended. This kit contains an assortment of five different spacers to achieve proper sprocket alignment. Individual spacers can be purchased separately. 99 models require splined Cam Sprocket P/N 25716-99 for installation. For race application only.
Specifications:
Lift @ valve Intake/ Exhaust (.510”/.483”)
Duration @ .053 Intake/ Exhaust (234°/239°)
Timing @ .053 lift Open/Close:
(Intake: 18° BTDC/36°ABDC
Exhaust: 42°BBDC/17°ATDC)
TDC Lift @ valve int/exh (0.178”/.152”)* Theoretical based on rocker arm ratio of 1.65. Valve train components, operation temperature and tolorence stack-up will affect actual lifts.
Fits 99-later Twin Cam equipped models unless noted. EFI models require ECM recalibration through applicable calibration cartridge or through EFI Race Tuner Kit. See EFI Race Tuner Kit for fitment or calibration matrix for possible applications.
Old 04-19-2010, 02:15 PM
jorswift's Avatar
jorswift
jorswift is offline
Will split the cam and other parts. Will take $115 shipped for the Tensionser & small parts to lower 48 states. Cams $125 + shipping. Thanks.
Old 05-04-2010, 07:45 AM
jorswift's Avatar
jorswift
jorswift is offline
bump...back on top...
Old 05-07-2010, 10:16 AM
Blown 331's Avatar
Blown 331
Blown 331 is offline
Just wondering if you take paypal?
Old 05-11-2010, 03:23 PM
jorswift's Avatar
jorswift
jorswift is offline
Yeah, I have a Paypal account I accept payment through.
Old 05-17-2010, 02:32 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,316 Likes on 1,444 Posts
PM sent.
Old 05-17-2010, 03:08 PM
jorswift's Avatar
jorswift
jorswift is offline
pm replied
Old 05-26-2010, 06:23 AM
akroguy's Avatar
akroguy
akroguy is offline
Sold?
Old 05-26-2010, 07:40 AM
jorswift's Avatar
jorswift
jorswift is offline
not yet, i got a local guy from craigslist interested. supposed to be coming by this weeke to look at them. will keep you posted. thanks.
Old 05-31-2010, 07:37 PM
shadylane's Avatar
shadylane
shadylane is offline
Do you still have the SE-203 cams for sale?
Quick Reply: Cams & cam parts
