Harley Davidson OEM Oil Cooler/Oil Radiator - $215 ($330 New) - Pricing includes shipping CONUS. Check out the pictures and PM me with questions.
This oil cooler came off my 2012 Road King. The cooler has a “Turbulator” system that evenly distributes oil across the cooling chambers, and the air fins are designed to efficiently dissipate heat.
Oil cooler used 1,100 miles
Horizontal mount
Air fins designed to efficiently dissipate heat
Large heat exchanger provides excellent cooling efficiency
Kit features a one-piece adapter plate with integrated thermostat that allows oil line to connect to the oil filter bracket
Thermostat activates at 185 degrees (85 degrees C)
Kit includes all required mounting hardware – you will need to get oil lines and 2 additional oil line clamps
Fitment:
Fits '11-'16 Touring and Trike models (except models equipped with Twin-Cooled engines). Stock on '11-'16 Touring and Trike models with 103CI powertrain option.
