Mark this thread as Unsold
Custom Dynamics Genesis LED Bullet Inserts
Used, front signals, sold bike $75 shipped.
Running light
Turn signal on.
GEN-200-AW-1157™ AMBER/WHITE DYNAMIC RINGZ™ FRONT 1157 BULLET STYLE LED INSERTS
THE ORIGINAL FULL FUNCTION AMBER/WHITE TURN SIGNAL
Front LED turn signal OEM replacement made with 48 5mm LEDs per unit. 1157 pigtail bulb base allows for plug and play installation with run and turn signal function! Our popular Dynamic Ringz™ allows the outer ring of 24 white LEDs to function as a running light and 24 center amber LEDs to function as the turn signal. When a turn signal is activated the White LEDs turn completely off for the entire turn signal cycle providing greater visibility to the amber turn signal. Must be used with a clear or smoked New Bullet style lens that fits the stock housing (sold separately). BCM Compliant. Lifetime Warranty against LED failure. Sold as a Pair.
Plug & Play on Harley-Davidson® US Models with front 1157 dual contact bases and OEM Bullet Style lens. View Additional Dynamic Ringz™ Fitments.
Does not Fit 2016 - 2018 CVO™ Models as they use JAE base turn signals.
Check out our premium ProBEAM® Amber/White Dynamic Ringz™ turn signals.
SMART Signal Stabilizer™ or Load Equalizer required when front or rear turn signals are converted to LED on 2013-Earlier Harley-Davidson® Sportster®, 2011-Earlier Dyna®, 2010-Earlier Softail®, 2013-Earlier Touring and Trikes and all V-Rod® models to ensure proper turn signal function and flash speed.
Running light
Turn signal on.
What did you have these on? I just spent part of my bike wish list money on some dumbbells and kettlebells for my home gym. Birthday is coming up Sat so maybe I'll get some money. I'll check back Sat or Sunday.
