FL-ViED-10
These have about 5,000 miles. Would like to get $50 shipped in the continental US
http://sales.nightrider.com/fl-vied-10.html
A simple, adjustable AFR, plug-n-play fuel management upgrade that fits 2010 and later Harley-Davidson Touring motorcycles, and 2012> Later Dyna, Softail and V-Rod. The FL-VIED-10 needs nothing more than a small screwdriver to fine tune the fuel mixture on your bike.
The FL-VIED-10 can be used on stock bikes, or those with upgraded exhaust and air cleaners.The FL-VIED-10 is recommended for motorcycles that have full exhaust system upgrades or stock exhaust headers with catalytic converters removed. The ability to fine tune closed loop the fuel mixture based on your upgrades make the VIED a universal installation for Riders. You can quickly adapt the mixture to your upgrades and riding style using a simple screw driver.
Nightrider's advanced patented design works inline with the heated Delphi narrow band O2 sensor and Delphi ECM to richen the fuel mixtures. Riders can quickly and simply richen the closed loop fuel mixture on your TC96/103/110 engine from the stock 14.6:1 to 14.4-14:0:1 AFR. The XiED's can add up to 6% more fuel to the engine in closed loop operating mode than a similar unequipped vehicle. There is an indirect richening of open loop fuel mixture's through the learning mode or adaptive fuel value action, ensuring these richer 13.8-12.5:1 AFR's are also adjusted in heavy/full throttle situations. This richer fuel mixture results in benefits that can include:
Cooler exhaust temperatures
Reduced engine temperatures
Improved throttle response
Less engine ping
Recommended for HD bikes with OEM emissions downloads. These include:
TC96, TC96 Stage 1
TC103, TC103 Stage 1, TC103 Stage 2
TC110, SE CVO 110
Upgraded exhaust systems including slip-on mufflers and full exhaust changes, and air cleaner upgrades are compatible with the FL-ViED(tm)-10 upgrade.
All XiED(tm) products are Protected by U..S Patent 7,805,236
VIED is a registered trademark of S&P Mullen Enterprises, Inc. Oldsmar, FL 34677
For Off Road Use Only
Less engine ping
TC96, TC96 Stage 1
TC110, SE CVO 110
ScreamingSkulls
Touring Parts
04-18-2016 08:12 PM
