Power Acoustik RZ4-2000D Amp
Used for about a hour. Thought I had a problem with the amp, so I ordered a second one since I couldn't return this one. (had it for more than 30 days) Problem wasn't with the amp. Works great, actually sounds a touch better than the one that's in the bike now. But I'm not swapping it back in.
It's like new, but the paper tag was damaged on the bottom from the foam tape I used to cushion it from the radio. Also one of the high level input harnesses was installed, just consider it pre-tinned. Still the factory length, just the ends were soldered at one time.
$75.00 shipped to your door.
Thanks, Justin
Thanks, Justin
