Custom Dynamics LED inserts
Bought for 07 sportster but does not fit since my turn signals have two inserts for the contact while this one has only 1. I believe this will fit other harley models. See Image
$60 shipped CONUS.
Got the below information from the custom dynamics website but please do your own research before buying
Genesis Rear Turn Signal
Bullet Style
(2x)
Red Single Intensity
New!
By Custom Dynamics
The Best LEDs Turn Signals On the Market Today Backed By the Best Warranty!
Lifetime Manufacture Warranty Against LED Failure!!!
Plug and Play - No Cutting, No Splicing; 48 Wide Angle Super Bright Next Generation Genesis LEDs per Cluster
Uses Existing Lens and Bucket; New Easier Install Bases
Fits all H-D Motorcycles with Factory Incandescent Bulbs, choice between Bullet Style & Flat Style (Flat Style fits both newer Flat and older Classic Style Turn Signals)
BCM Compliant LED Turn Signals work on all CAN Bus/BCM HDs, no load equalizer is required, LED will flash at proper rate, no codes.
$60 shipped CONUS.
Bullet Style
(2x)
New!
By Custom Dynamics
Garemlin
11-17-2013 09:59 AM
