FS: Speed Rings 2014-23 Harley plug and play Adapter 4 channel line driver for stock radio
$200 with shipping to USA only.
Used for a few weeks in a 2017 Street Glide 4 speakers set up. Designed for adding an amplifier to your stock radio. PLUG AND PLAY T-HARNESS FOR 14 TO 23 HARLEY DAVIDSON SPECIFICALLY DESIGNED FOR SOUNDIGITAL AMPLIFIERS Works with all amplifiers A simple solution that works with your stock radio to add to an amp on a 2014 and up Harley Davidson GT and GTS Radios. Plug and play, no splicing or cutting wires at all Labeled for easy installation Built-in remote wire for amp turn-on RCA inputs from Axxess box to amp front and rear Most radios need to be flashed to turn the rear outputs on CVO needs to be flashed to remove boom amps in radio settings Works for CVO and Ultra also uses existing front and rear wiring Eliminates the need for Pod plug to amps Outputs for front pods to amp Rear outputs for stock wiring (CVO Boom lids and Ultra Rear Tour Pak Pods) Works with SounDigital Amps and the DS18 ION Series Amplifiers, as well as most all brands Preferably not for use with a DSP Preferred Harley Davidson Flash 8 speakers, 2 amplifiers or 4 speakers, no amp.
bykw2
11-07-2019 09:35 PM
HARLEY100TH
Audio Systems
19
09-01-2019 10:33 PM
