Mark this thread as Unsold
FS: X2 BT355 line levelers
X2 biketronics line levelers, BT355. Plug and play or cut the plug and wire in.
Both are used and come off a build changeout. Work flawlessly
$60.00 for both or $40.00 each.
I dont know if they are both a factory default as I didn't verify before removal. I'd have to "assume" so because when I installed them several months ago they were and I feel fairly confident they were not touched since. Easy enough to reset WITHOUT speakers hooked up.
The connector is for the harness/speaker so one in the same.
