Upgrading SE 131 kit
Old 08-23-2024, 05:39 AM
oldman131's Avatar
oldman131
oldman131 is offline
4th Gear
Default Upgrading SE 131 kit
2021 Street Glide se131 kit,
I like the 131 kit with the 517 cam I would like a little bit more on the bottom but I feel like I fall on my face once I get moving if that makes any sense.
I just purchased power vision pv3 B looking for a cam and pipe? From everything I read I'm leaning towards andrewe 554 or 837 B cam and khrome Werks 2-2 3 step. And bigger injectors but I won't know that absolutely until it's dyno.
Old 08-23-2024, 06:13 AM
mstrobes's Avatar
mstrobes
mstrobes is offline
Yes the SE517 is a high rev cam. I didn't like it for touring. I went with the Woods 77x. Very good low end torque.
Old 08-23-2024, 09:52 AM
oldman131's Avatar
oldman131
4th Gear
I'm looking for something with a little more mid torque
Old 08-23-2024, 12:23 PM
mstrobes's Avatar
mstrobes
mstrobes is offline
go look at fuel moto site. they have a bunch of dyno charts on different cams for the 131.
Old 08-23-2024, 02:42 PM
Bigt001's Avatar
Bigt001
Bigt001 is offline
TTS 250 cam with the Khrome Werks exhaust with louvered baffles work very well.
Old 08-23-2024, 03:24 PM
oldman131's Avatar
oldman131
4th Gear
I've been through all their dyno pages that is what pushing me towards the bigger cams
Old 08-23-2024, 03:27 PM
oldman131's Avatar
oldman131
4th Gear
I seen these cams also but I don't know if they're dropping cams with my Screaming Eagle valves Springs I've been talking to Harley shops all over I know Andrews 554 and 837 B cams can be just set in don't want to open up the top end yet
Old 08-23-2024, 04:39 PM
oldman131's Avatar
oldman131
4th Gear
I really love those numbers but my stock compression 10.7 Maybe I'm sure that Dyno Run is not stock se131.
but I do like the lift on those easier on the valve train I would think I really appreciate everybody's important
Old 08-23-2024, 05:29 PM
Bigt001's Avatar
Bigt001
Bigt001 is offline
There are a couple of YouTube videos out there where JD Cycle Works did that combination on a stock compression 131 and the numbers were very close to mine even with my added. 11.3:1 compression. His made better torque earlier.
klammer76 (09-01-2024)
Old 08-23-2024, 05:47 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,181 Likes on 3,364 Posts
Check out the CR512, and the CR515 as well.
I really like the looks of that TTS250 sheet, I keep coming across it. I need to check and see if they are at home in a 10.8:1 big bore.
Quick Reply: Upgrading SE 131 kit
