Correct and upgraded Screaming Eagle oil pump
I wouldn’t trust the S&S cam plate if not using a straighten and welded flywheel, cuz if it develops a runout higher than 5 thousands, the brass bushings cold twist causing the oil feed holes of the bushing to misalign with oil hole from the plate starving a lot of engine components of oil. The brass bushings from the S&S cam plate has no splines to prevent twisting the S/E cam plate does and won’t twist, and are designed to handle up to 12 thousands of runout.
talkingrock (10-07-2024)
Don't get me wrong, if this is in fact the case, it might help me make my decision
I am now torn...
I think one of the advantages of the SE one is that the brash bushing is key'd in so it cant rotate like the SnS one can.
I doubt this has much to do with run out tolerance but I wonder if it helps.
When I pulled my SE plate out and looked at it I couldnt see any witness marks or anything that would make me curious or worried about run out, and I never measured the run out of my crank.
But I also installed it with faaaar more focus on trying to ensure it was centered.
I described the method I used to Master Tech Miller a while ago and he said I've got nothing to worry about.
I am curious how they managed to allow out to 12000 though.
Thumper87
06-29-2015 07:18 AM
electraglidenblue
07-16-2007 01:26 AM
