Piston Wear
Received 22,422 Likes
The following 2 users liked this post by CoolBreeze3646:
Bayou FLHR-M8-128" (02-12-2023),
gravybiscuit (02-12-2023)
CoolBreeze3646 - everything has been covered and closed up with plastic - appreciate that feedback!
Lonewolf; that's pretty interesting actually - you may have something there. I am going to get some better pictures in goo lighting and see if I can figure that out more.
I do have new oilers to install however, I will be checking the old ones out of curiosity. Probably check the new ones as well! I have a habit of replacing everything while I am 'in there'
I guess the consensus is that the my pistons tops/carbon are worse than the skirt wear!
Chris
Chris
VernDiesel (02-12-2023)
The wear would be normal if the piston clearance was tight.. That coating is designed to help keep the fit tight so the motor don't rattle when clearances are loose and wear down when the clearances are tight. You probably had bore on the small side of the tolerance and a piston on the large side.. It does look like the rings didn't seat all that well tho.. Poor cylinder finish or not a good break-in.
