Aftermarket tuner question with screaming eagle tune
Looking to see if anyone here knows if I can use either a fp3 or 4 or the pv4 with a screaming eagle download already in the ecm? Does it save the file and just replace it with their version? Just about to run out on the warranty and wanted to put a better system on. Thanks in advance.
True, but not relevant to the OP's question. The FP3, 4, PV, SE tuners are all are flash tuners, so a new map would be flashed to the ECM. What was there before doesn't really matter.
The next question usually is "can I put the old map back before I take it in for a warranty claim?"
Answer is yes, but the fact that you used an aftermarket tuner to flash the ECM would be detected by the moco, so it would be pointless to do so.
Yes you can flash over the existing tune. And, as said before, you could then use the SE tuner to restore that tune, if you needed to.
The following 2 users liked this post by smithmoto:
binarym (07-11-2022),
Cosmic Razorback (07-04-2022)
