Hydraulic clutch for 2021+
Old 06-30-2022 | 06:28 AM
lp's Avatar
lp
M Oclaf (06-30-2022)
Old 06-30-2022 | 06:38 AM
M Oclaf's Avatar
M Oclaf
Love that hydraulic clutch, makes me believe i am riding a 20th century bike, not a 1900's harley...best of luck, may try to peruse some salvage sites? it wouldnt be "M8" specific, but the model years from what, 14 on up? the latest frame and trans combo...has to be something out there you can get on the cheap end money wise, clean it up, install and go...even if Harley puts that new motor in a touring bike but doesnt go back to a hydraulic clutch pull, i bought my last one. Same folks who complain how Harley is cheap when it comes to suspension and what have you are the same ones touting a cheap *** clutch cable as a saviour...kills me.
voodoodrug (06-30-2022)
Old 06-30-2022 | 06:45 AM
gonemad's Avatar
gonemad
Which Harley’s have you owned with a cable clutch? I owned two Evos and a 2020 with hydraulic. Owned one of the Evos and the M-8 at the same time.
Even with the Muller Hydroclutch slave cylinder installed on the M-8 the old cable clutch was vastly superior in it’s operation. No comparison, and that was on a 1995 that sat up for 15 years.
Old 06-30-2022 | 06:59 AM
smitty901's Avatar
smitty901
Originally Posted by FLTRI17
I’ve adjusted the cable twice for dialing in the friction zone. So far the plastic parts seem to be holding up fine. 🤞
I really like how easy it adjusts. Lift up the cover. Pull the clip. Adjust the cable as desired. Put the clip back in. Lower the cover. Done. Only tool required was a needle-nose to pull the clip.
Time will tell how the plastic parts hold up.
I believe there are already metal aftermarket replacement parts either for those who have broken their plastic adjuster or assume it will break and want to prevent the possibility of failure.
Bob
Aftermarket had to step up. So many were breaking And HD did not have parts. New bikes sitting due to the part breaking.
Old 06-30-2022 | 12:11 PM
mikes300's Avatar
mikes300
hahahha define vastly superior, the cable is a big step backwards over a juice clutch, virtually every other manufacturer has used them since the late 90's why do you think that is?
Old 06-30-2022 | 12:12 PM
mikes300's Avatar
mikes300
Originally Posted by NorthWestern
Please include a Muller in that, instead of the HD slave, it is ****.
Rekluse makes a great slave cylinder too.
The following 2 users liked this post by mikes300:
TOFTS (06-30-2022), Ya Tigor (07-01-2022)
Old 06-30-2022 | 12:14 PM
gtrplyr's Avatar
gtrplyr
Originally Posted by $tonecold
There is no kit from Harley, but you can buy the parts from them. You're looking at about $800. I don't have time right now, but maybe tomorrow I can put the part numbers together for you.
Thank you! That would be greatly appreciated.
Old 06-30-2022 | 12:16 PM
TriGeezer's Avatar
TriGeezer
Bob
Adjusting just the cable does not change the friction zone. It’s just changes the free play.
dajogejr (07-01-2022)
Old 06-30-2022 | 12:17 PM
gtrplyr's Avatar
gtrplyr
I found that late last night. Seems like AIM’s reviews vary. One thing they noted that I hadn’t considered is the need for a clutch sensor. Seems without it the bike starts in gear.
Old 06-30-2022 | 12:23 PM
TriGeezer's Avatar
TriGeezer
Harley should have figured out how to fix their implementation of the hydraulic clutch rather than dumping it and going back to stone age technology. Maybe they should have studied the hydraulic clutch implementation on other bikes. I improved mine with the AIM slave (am I allowed to say that?) cylinder. It reduced the pull effort, which my busted up hand needed, and slightly widened the friction zone.
I could see that the OEM hydraulic clutch would be a PITA for police rodeo competition. It was an extreme PITA & PITHand in traffic. Over time I’ve learned to contend with the still not optimum friction zone width. It’s still too much off & on. At least the clutch doesn’t slip.
NorthWestern (06-30-2022)
Quick Reply: Hydraulic clutch for 2021+
