Exhaust gasket install tool
I was talking to a friend about giving me a hand throwing on a new head pipe and he was asking if I had an gasket install tool. I’d never used one before and started googling. All I found for was for evo and TC no m8. Is there any difference between the way the pipe sits on the head between the TC and m8?
this is the tool in question for reference
Exhaust Gasket Seal Installer Tool for Harley Davidson use on Evolution Big XL Twin 1980-2016, Red https://a.co/d/daKZ81C
I believe this is the tool.
https://www.builderstools.jimsusa.co...ket-installer/
When I was reinstalling my exhaust I ordered an exhaust flange when I ordered the gaskets, and just pressed the gaskets in with the flange, screwed down with the two nuts on the studs.
Bayou FLHR-M8-128" (06-09-2022)
The following 5 users liked this post by QC:
6113_ (06-05-2022),
CPete13 (03-10-2024),
havinabubble (06-07-2022),
Zedbra (06-10-2022),
Zonktified (06-06-2022)
Kinda think your over thinking it. If you worked in a Harley shop and ever minute counted to you, maybe.
Line up header pipe so you don't need to juggle it doing it.
Careful push in the crush gasket. If it's lose,. Stick it with whats handy. Install header square and stug up the stud nuts.
Not an expert and only done 5 but I'm not sure why you need a tool. Ever one I pushed in were snug enough and flexible enough they went in and they stayed in from finger pressure .
That tool in 5 is a free loaner tool at AutoZone. I borrowed it and another when I rebuilt my 4 cylinder, transmission and transfer of my 93 Wrangler.
I put my M8 exhaust gaskets (Cometic) in the freezer over night. I cleaned the carbon from exhaust ports fairly well where the gaskets fit, and was able to push them in by hand with very little effort. The gaskets did not distort while pushing them in.
Tighten the nuts evenly to crush / spread the gasket evenly, following the procedure in the manual. Then final torque following the specs.
Paul
Paul
The following 2 users liked this post by pgreer:
Bayou FLHR-M8-128" (06-09-2022),
Jackie Paper (06-09-2022)
