Engine hitting frame
RGR. I tried everything to get mine re-centered (cause I though something was wrong) to the point I broke the center piece off. Took it in to HD and they put a new mount on. New mount looked identical.
Tech walked me around to another new bike that was on a lift and it was exactly the same. Whole ordeal was a waste of time and made me feel stupid.
When I say I tried everything, I mean I loosened all (4) the mounts, wiggled the engine/trans, used a scissor lift under the engine, a pry bar, some thoughts and prayers, nothing would center it.
Being the obsessive type, I also went as far as getting an adjustable top engine mount. Only then was I able to closely center it and then 15K miles later the rear tire had irregular wear on the one side.
Took it off and went back to stock and it's been fine that way for 40K miles.
Anyway, just sharing my experience. Good luck to your Sir.
