Scenes from the highway shoulder...
Old 08-19-2021 | 09:13 AM
strych9's Avatar
strych9
Unhappy Scenes from the highway shoulder...
The ol' RGS let me down last night.
I took a nice little ride outside of the city after work yesterday evening, and the weather was excellent. I figured on 60-70 miles and was thoroughly enjoying myself. Shined up nice, running great, feeling good. On my return trip to home, I decide to take the freeway for the remaining 10 miles. As I made my right turn onto the on-ramp, the engine just gently stalled without fanfare. Not a single hiccup prior to that. I glided to the shoulder and attempted to restart. Nothing. Not a click, grunt, nothing. All indicators working, about 12.5v showing on the gauge. Clicked over the kill switch a couple of times just for the sake of elimination. Still nothing.
Roadside code check:
P1511 EFI Power Management Mode
P1514 ETC Air Flow Fault/Error
P2105 EFI Forced engine shutdown
P2135 TPS Correlation Error
After clearing the codes, the bolded ones came back immediately as hard faults. The bike did crank and start after clearing, albeit in limp mode. Fortunately my buddy was able to get my trailer to me and we loaded up my bike and hauled it home without further incident.
Tonight I will be doing some diagnosis, and worst-case scenario will be a failed throttle body assembly. It's a Screamin' Eagle unit, and if that's the failed component, I really, really hope I can get one in time to keep my appointment with Fuel Moto next month. I still have the stock unit sitting on a shelf in my garage, and that'll be my test equipment used this evening, along with my PV2. I'll follow up on the thread when I figure this out. Wish me luck!
Popular Reply
08-19-2021, 09:02 PM
strych9's Avatar
strych9
Arrow
Well, the fix was a bit simplistic: a little thing called "terminal abrasion". If the pin fit between a male and female terminal is anything less than tight, vibrations can cause them to "abrade" against each other, resulting in something similar to corrosion. The throttle body pins (both male and female) are gold-plated on 2010-on model years, and therefore practically impervious to chemical-reactive corrosion. But they are not impervious to abrasion.
Long story short, I took the TB connector apart and polished the offending terminal, pinched it slightly for tighter pin-fit, and Bob's your uncle. She's running normally with no codes.
As an aside, the early drive-by-wire models did have corrosion issues on those pins, and my codes lined up with that issue and led me to the root cause after researching the internet.
This fix cost nothing but time. Hallelujah!
Old 08-19-2021 | 09:21 AM
CrBear's Avatar
CrBear
Good luck with the repair and good you had a place to pull over. I hate pulling on the shoulder. dangerous these days.
Let us know how it turns out.
Old 08-19-2021 | 09:22 AM
TexasD's Avatar
TexasD
Hey Strych9, sorry to hear about your troubles. I noticed in your 25k service thread that you are running a PV Target Tune, any chance that this could be the culprit? In my hours and hours of researching TT before purchasing one, I saw a few instances where the O2 sensors had gone bad or where loose wiring (at the TT module itself) had caused some funky issues with the bike.
Just a thought. Hope you get it sorted out quickly and painlessly either way.
Old 08-19-2021 | 09:26 AM
strych9's Avatar
strych9
Thanks, bud. The codes I pulled are relatively common, albeit for older bikes. I might suspect the TT if I had a CEL with some O2 codes or something, but the codes I do have are directly related to the throttle body. Thanks for the suggestion, I will keep it in mind. I'll get down to the bottom of it.
TexasD (08-19-2021)
Old 08-19-2021 | 09:28 AM
tunaman's Avatar
tunaman
Damn, sorry to read this and hope you get it sorted quickly and painlessly!
Seeing your thread title, I thought it was a creative thread of a photo collection - you gave me a great idea for a photo project.
theheder (08-19-2021)
Old 08-19-2021 | 09:32 AM
strych9's Avatar
strych9
LOL, I should have taken photos!
Old 08-19-2021 | 10:06 AM
sixguns's Avatar
sixguns
Similar event on my brand new 2017 stage III, the Heavy Breather element failed, a chunk of epoxy inside the filter came apart and jammed the Throttle blade. Good thing the computer freaked out and shut her down.
strych9 (08-19-2021)
Old 08-19-2021 | 10:50 AM
teedoff65's Avatar
teedoff65
Haha! I thought the same thing!
Sorry about this man, I'm sure you'll get it figured out before your FM appt. But obviously, you've put over 25k on it, so odds are something might give out after that many miles. Hopefully its a simple fix.
The following 2 users liked this post by teedoff65:
strych9 (08-19-2021), theheder (08-19-2021)
Old 08-19-2021 | 01:17 PM
mjwebb's Avatar
mjwebb
Originally Posted by strych9
The ol' RGS let me down last night.As I made my right turn onto the on-ramp, the engine just gently stalled without fanfare. Not a single hiccup prior to that. I glided to the shoulder and attempted to restart. Wish me luck!
undoubtedly you'll get things sorted out and back to riding soon...of all the bad things that can happen and places to be when a bike just up and dies on you, just glad to hear it was where it was and you were safe!!!
Old 08-19-2021 | 01:33 PM
strych9's Avatar
strych9
Thanks, brother. All things considered, the positives are that I was fairly close to home, was able to get it home without a paid tow, and the failure is relatively minor. Cash and time will git 'er done. Hopefully less than more.
Quick Reply: Scenes from the highway shoulder...
