Best clutch basket?
#51
Redbeard719 (07-06-2021)
#52
Mchad (07-08-2021)
#53
NorthWestern (07-08-2021)
#54
So I just read in the SM that the c-clip was directional - flat side towards bearing. I totally missed that too, when doing the job. Luckily when I re-read the section they were referring to the bearing retaining clip, not the one on the hub. But I remembered removing the clip and setting it down in the direction it was installed, so that’s how it went back. Since it wasn’t specified it doesn’t matter, but luckily it went back the way it came out.
#55
#56
#57
VDeuce (07-08-2021)
#58
#59
Thanks boys. I looked around locally and of course no one had press blocks for sale. How does Harbor Freight not even have a small set? If anyone has suggestions on a kit, let me know please! So I dug deep into my “bought for one use” tool draw and found a 36mm socket that coincidentally just cleared the shaft of the hub, which was 1.3” diameter, and also made solid contact with the inner bearing race. Lubed it up with primary fluid and it pressed right in. Nice.
That compensator bolt was the bitch, because my breaker bar was only like 16” long. Even heating it to over 500 it seemed like it wouldn’t budge. Of course after practically crapping out my kidneys I muscled it off with that pee-wee breaker. I thought to myself “why didn’t you just use the 1/2” torque wrench sitting on the stand, you stupid idiot..”
Everything else was cake. Once I figured out the press issue and recovered consciousness from the breaker bar incident, everything else went together quick and easy. Reused the Carbonite clutch I got from FuelMoto, Buttoned it up, cleaned up and came into the AC and drank about 3 gallons of ice water. Garages in f***ing Florida summers with only a fan isn’t fun.
Didn’t get to test ride, but unless I screwed something up, there really shouldn’t be any difference. Just that this won’t eventually fly apart…
As usual, I suck at photos, but here’s all I got.
#60
Thanks
