Stage 2 worth it?
Top Answer
03-26-2021, 06:03 AM
Cam swap is the single best bang-for-your-buck upgrade you can do.
If you want truly stellar results, go with an aftermarket cam, not the anemic HD torque cam, and a PowerVision tuner. You will have zero regrets.
empowered01 (02-04-2022)
The following 10 users liked this post by NorthWestern:
92evo (03-26-2021),
gunnar (04-02-2021),
luckiestiff (03-26-2021),
mazz (03-27-2021),
NAPRA (03-26-2021),
and 5 others liked this post.
how much do you both weigh is another unmentioned factor...needs may change if together you're 350 or 500 and also how much of your 50/50 two up is loaded down for out of town trips..shifting around 3500 on average is pretty normal but you should be winding it up more than that often as well to get the use out of the power you have paid for and also to help keep the engine burning cleaner..it can handle it, it's designed to safely wind up to 5500 but in stock or stage 1 they really have given their best by 4500 and beyond that just sucks more gas and increases wear and tear
The following 4 users liked this post by SWFLGuy:
U are correct, there is nothing wrong with the HD torque cam, but the only reason to put the HD in over aftermarket, would be to keep warranty.
well, that obviously but the SE may only need the ecm recalibration with SEPST to perform spot on whereas aftermarket cams may be finicky with tuning and require dyno tuning sessions to get dialed in and more finicky depending on exhaust, intake, etc....to many the extra time, expense and fussing with autotuning and dyno tuning is well worth getting the extra power..others may be perfectly happy with a simple 'less is more' approach
Short answer is Yes, a cam upgrade is a very noticeable gain in power. To upgrade or not is a personal decision, if you feel your bike is under powered, start adding power boosters till you're happy. I ran a stage III on my 17 Road Glide, full Aftermarket stage II on my 18. I'm on a 2020 Road Glide Special now and love the bike with just pipes. I don't miss my old bikes at all...
The following 3 users liked this post by sixguns:
Robertashby (04-02-2021)
