MY 2021 FLH/FLT hardware updates & changes
Old 01-06-2021, 06:25 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,160 Likes on 1,354 Posts
Default MY 2021 FLH/FLT hardware updates & changes
Model 2021 FLH/FLT Touring platform has received several key updates relative to electrical hardware among other changes. We'll post more info as it comes available.
new Delphi MT22 ECM
new ISO 19689 OBD data port replaces the current 6 pin data connector
other 2021 FLH/FLT notes:
  • RDRS is now standard on all models except Electra Glide Standard, base Street Glide, base Road Glide, and base Road King
  • same 12mm heated O2 sensors as previous models
  • same exhaust system fitment as previous models
  • cable clutch actuation on each of the models we inspected including Tri Glide
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The following 5 users liked this post by fuelmoto:
biglew55 (01-07-2021), jammerx (01-09-2021), Jehu (02-13-2021), MoneyFor (08-17-2022), smitty901 (01-08-2021)
Old 01-06-2021, 06:33 PM
woodreaux's Avatar
woodreaux
woodreaux is offline
Thank you for the report. Looking forward to reading your future discoveries.
Old 01-06-2021, 06:43 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,343 Likes on 4,767 Posts
thanks...any initial thoughts on why the ECM change? understand too early in the game obviously..so maybe the question should be..after 4 MY did you have any thoughts on the ECM that was introduced for the M8s, i.e; issues / concerns / shortcomings, etc. that may have prompted the change? maybe it's as simple as advancements in electronics technology has been the fastest moving its ever been over the last decade
Old 01-06-2021, 06:56 PM
teedoff65's Avatar
teedoff65
teedoff65 is offline
Received 1,526 Likes on 1,089 Posts
to discourage using aftermarket tuners is my guess. Or make it harder to program tuners that will work with the new ecm.
mjwebb (01-06-2021)
Old 01-06-2021, 07:13 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
good point..come to think of it..over the last 4 years we've heard of about every conceivable problem the M8s have had, but the 'brain' being problematic wasn't one of them that I recall
Old 01-06-2021, 07:16 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
There are two main considerations; costs (actually cost savings) and emissions standards and compliance. The primary factor for the ECM change is very likely Euro 5 emissions standards. While aftermarket tuning may be a concern its nowhere near large enough factor to make a hardware change of this scope. On that note the Delphi MT22 ECM is actually a pretty widely used piece of hardware, depending on the chipset they are using I expect aftermarket tuning should be pretty straight forward.
The following 3 users liked this post by fuelmoto:
Jehu (02-13-2021), mjwebb (01-06-2021), teedoff65 (01-06-2021)
Old 01-06-2021, 08:02 PM
470004's Avatar
470004
470004 is offline
Received 16,243 Likes on 6,722 Posts
Thanks for the information and sharing.
Old 01-06-2021, 08:23 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,600 Likes on 2,723 Posts
Why upgrade your laptop? Same idea.
Old 01-06-2021, 08:39 PM
teedoff65's Avatar
teedoff65
well if they are purposefully coding ecm modules to try and prevent third party products from working, then eh. Not good. I dont buy a laptop and then set it up so I can't use third party text editors....
Old 01-06-2021, 09:28 PM
vhmike73's Avatar
vhmike73
vhmike73 is offline
The problem with that comparison is that your third party text editor won't get Dell or HP into a multi-million dollar quagmire with Uncle Sam and the EPA.
And now that the Dems appear to have full control over the Legislative and Executive branches in Washington, you can bet that all the regulatory reductions that happened from 2017-2020 will be reinstated with a vengeance- and companies that produce internal combustion engines will be targets.
The following 3 users liked this post by vhmike73:
smitty901 (01-08-2021), teedoff65 (01-06-2021), wmprof (01-13-2021)
Quick Reply: MY 2021 FLH/FLT hardware updates & changes
