2019 Road Glide Ultra with Boom GTS. I found a nice set of pre 2020 used CVO wheels and had the TMPS monitors (32700052) installed with the new tires.
The dealer said the system was activated via the Digital Tech but will not display on the Infotainment screen. They tried a couple different things but could not get it to display. They have a call into Harley Tech Support but won't hear back from them until next week..
Have any of you who added the TPMS monitors had this issue? What was the fix? TIA
they have to enable tpms in the radio and in the BCM to see it in the odometer and radio, also they have a special tool to activate the sensorsm it tells the bike which sensor is front and rear
As far as I know the TPMS option to upgrade is only applicable to 2020 models. The only 2019 models that have the TPMS are the CVO Models. The BCM Module is apparently different on the 2020's.
i know a guy who did this to his 2019 rgs. he said, "Nothing needed but the sensors and the Digital Technician to activate them in the BCM and the readout in the radio, and the hand held unit to tell the seniors which one was which".
Inaccurate. The 2019 bikes have the GTS Infotainment system and the TPMS is in the system but has to be activated. Several people on this board have already done it.
mine is a 2017 special with cvo wheels, tpms worked on the gt6.5 then i ugraded to the gts radio and on works on it.dealer has to set up the radio and bcm, then go to info screen and click on more, thats where you will see the tire pressure
Thanks for the advise. This is info screen? There is no "More" to be found on the 3 info screens. What I find odd is they said they got it activated but it won't display on the screen.
