then they didn't do something correctly. once it's activated, you should have 4 screens for info, tire pressure being one of them.
My bike is a 2019 RGU with the GTS infotainment.
My dealer is having trouble getting the TPMS system to display on my screen. He said they called HD and they were of no real help.
He said they got the system activated but can't get it to display on the screen. Do any of you that have had it done have any idea what they did to get yours to display?
an you see the tire pressure in the odometer, if so then the bcm was flashed , then have dealer go into the radio set up using there computer and check off tpms
Mine is a 2019 with the BOOM GTS, It should be displaying on the screen and not on the ODO window.
The only way it will display in the odometer is IF you have a 2020, 2020 gauges, CVO, CVO gauges, or the P&A gauges. If you have a bike that was not original equipped with TPMS (unless it is a 2020) the ONLY place the TPMS will display is on the radio.
I installed those TPMS on the wheels on my 2018 FLHXS. I then used DIAG4BIKE to assign each front and rear TPMS to the BCM of my bike. I then used the DIAG4BIKE to unlock the feature on my upgraded GTS infotainment system. Everything has been working excellent. The pressures even display on my Dakota Digital Speedometer.
