sometimes hd makes it tough. look at the bars on the very last line of the attached (55800332). these are the bars that are on the roadglide standard, which are the same as the special only chrome instead of black. the black ones are part number 55800378, which are not included in the handlebar spec book.
I think its 9”, i put 12 in kst on mine if you ever want to sit on it and see how you like them.
Looks like your RGS is River Rock Gray also great color! I Funny the KST are on the top of my list I like the fact that that you can adjust the grip angle were you able to do 12's with the stock cables?
if you are looking for bars check out Thrashin Supply. I have all my parts ordered for my 19 Road Glide. I went with the pull back plate with 6.5 pull back risers and the high bend bars. Check out his video.
I had 12" KST bars on mine with stock cables. Granted it was the meyhem bars and not the adjustable KST bars.
Just went to 14" factory 47 and still used stock cables and wires.
yes no issues with the stock cables and i added in heated grips as well
