Built-in / Normal M8 Vibration
#51
I'm coming from a Buell XB12Scg that had a lot of its own vibrations, but I have to say my stock 2020 Fat Bob 114 with 2,000 miles has way more vibration than I expected. I can't believe Harley considers this to be smoother. My hands will tingle after 45 minutes or so. Are there any padded gloves and handlebar bushings and/or bar snakes you'd recommend?
Also, I've read conflicting information. Does the Stage II Screamin' Eagle SE8-447 torque cam add more vibration? I understand valve lift will be changed, but I can't see this adding much more vibration if any.
Crispy (09-21-2021)
#52
#53
#54
#55
#56
some have claimed that poly bushings make the vibes worse on the new softail’s. 6.5 risers with stock bar and bushings, no vibes here!
#57
Yeah I doubt my reduced vibes are attributed to the bushings as much as the bars. Maybe stock rubber bushings would be even better, idk. All I know is I don't even notice the vibes, now.
Durham man (09-28-2021)
#58
