Who has a weird idle on their M8???
Old 04-07-2020, 06:45 AM
sandrooney's Avatar
sandrooney
sandrooney is offline
Default Who has a weird idle on their M8???
Mine has always idled weird. When I am coming to a stop it idles up a little till stopped. After turning engine off for a few minutes it will idle up when I take off. It's not the EITMS, I know what that sounds like. I have checked for intake leaks and there doesn't seem to be any. I have read where others have had issues, so thought I would ask here for a fix if any.
Thanks
SR
Old 04-07-2020, 07:00 AM
CoolBreeze3646's Avatar
CoolBreeze3646
CoolBreeze3646 is offline
Received 22,174 Likes on 7,673 Posts
Thanks
SR
Try this:
To reset your idle setting back turn the ignition switch on for 10 seconds off for 10 seconds (do not start the engine), repeat a total of 4 times. That should reset your original throttle position. The tech who was working on your bike may have shut it off with the kill switch while it was idling a little high.
Other than that you may want to check all your throttle by wire connections.
Old 04-07-2020, 07:06 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,481 Likes on 761 Posts
What you describe can be caused by a faulty clutch switch. Will your bike start in gear with the clutch lever pulled?
Superdog3:16 (04-08-2020)
Old 04-07-2020, 07:47 AM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,365 Likes on 4,776 Posts
my 2017 oil cooled 107 idle behaved erratically on occasion but now with almost 6000 miles in 7 months my 2020 oil cooled 114 has yet to exhibit that
Old 04-07-2020, 09:37 AM
wmprof's Avatar
wmprof
wmprof is offline
Received 1,297 Likes on 446 Posts
Mine started doing the same thing after about five thousand miles. I ordered the Aluminum Intake Manifold because I think the plastic one is Warped. I'll let you know after I get it installed if it's fixed it. Prefer to to have a metal intake anyway.
Old 04-07-2020, 10:32 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,608 Likes on 2,727 Posts
Curious - part number? Thanks!
Old 04-07-2020, 10:35 AM
sandrooney's Avatar
sandrooney
Originally Posted by coolbreeze3646
Try this:
I tried that. Thanks
Old 04-07-2020, 10:36 AM
sandrooney's Avatar
sandrooney
It will start in gear. Thanks
Old 04-07-2020, 10:38 AM
sandrooney's Avatar
sandrooney
Please do. Thanks
Old 04-07-2020, 10:56 AM
KrustyKush's Avatar
KrustyKush
KrustyKush is offline
As I recall, mine would start in gear sometimes, and not other times, until I had the clutch switchpack replaced under warranty. Therefore, it is possible that a bad clutch switch is the culprit, even if it doesn't prevent the bike from starting.
Quick Reply: Who has a weird idle on their M8???
