tuner question
tuner question
Hi was wondering i have 2019 114 street glide special and it had the SE pro tuner and stage1 flash.After warrenty is up i am going with a different tuner when i do my cams.Other tuners say you should go back to factory flash.Is there a way to get a hold of the stock flash without paying harley for the flash?If i can get the flash i would just get a cable and reflash it my self.Thx
what part does not make sense? if i go to vance and hines fuel pack they said you should put the factory flash back on the bike.Since harley flashed the bike for stage1 with SE pro tuner i wouldnt have a copy of the factory flash.When i hook up Se tuner all that would be there in the VCI is the Stage1 flash.I would not have a copy of the factory flash
jd05flhtci (02-10-2020)
so just curious and thinking out loud..is Stage 2 with as far as you plan to go? if so and you are just looking for some extra 'oomph', to keep things simple you could just install the SE447 Torque cam which from following here the majority that have done so feel like mission accomplished / good enough. you could just do the SEPST calibration, run auto tunes or have it dyno tuned and it should run great..but if you're looking to get the most out a Stage 2 then aftermarket cam, tuner and a good dyno tune is the route folks prefer
