Spark plugs loose? Yes
Old 01-05-2020, 04:59 PM
deckdr's Avatar
deckdr
deckdr is offline
Default Spark plugs loose? Yes
After reading numerous posts about spark plugs that weren’t tight from the factory, I decided to pull the tank and check. Sure enough the two up top were only finger tight. They could be removed without any torque.
Thanks to all who shared this here. 👍
2019 Road Glide 114 M8 5k miles
Old 01-05-2020, 08:37 PM
nightrain88's Avatar
nightrain88
nightrain88 is offline
Another Just WOW moment!!!!!!!
Adams17RG (01-06-2020)
Old 01-05-2020, 10:10 PM
touchdown's Avatar
touchdown
touchdown is offline
Received 1,785 Likes on 1,017 Posts
I will take a look at my plugs, are they on the top or under the bike.
Old 01-05-2020, 10:15 PM
hollandhunter's Avatar
hollandhunter
hollandhunter is offline
One of the dumbest things harley ever did was put plugs under tank. Its routine maintenance turned into advance maintenance. Would be like having to remove a altenator to get to your oil filter on a truck. But its the price we have to pay to run a m8.
The following 3 users liked this post by hollandhunter:
GPHDXLC (01-12-2020), mjwebb (01-05-2020), Uncle G. (05-27-2020)
Old 01-05-2020, 10:21 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,371 Likes on 4,780 Posts
no $h!t..stupid, they'd sell twice as many spark plugs too if they made it more DIY friendly
Old 01-06-2020, 04:57 AM
19special's Avatar
19special
19special is offline
Yep, 4 bolts, a quick connect fuel line, a couple electrical plugs, and a vent tube or two shoves it way past the comfort zone of many. That is some major advanced maintenance there now. Kinda like putting brakes on your car.
Ohh, all 4 of my plugs were tight.
The following 2 users liked this post by 19special:
BrandonSmith (01-06-2020), hattitude (01-07-2020)
Old 01-06-2020, 05:35 AM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
i've made that mistake in the past ,once it ran rough,other time blew all the way out, had to ride to safety on one plug and it was not too bad,bit surprising.
now with 4 plugs all you might notice is your getting 58 mpg?
Old 01-06-2020, 05:37 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,072 Likes on 2,507 Posts
I R&R engines so removing the tank is no big deal. But, every time you R&R the tank you run the risk of cutting/pinching the o-rings on the connector and causing a leak, not to mention it's a chance to drop or damage the tank. More importantly, that means the plugs under the tank will only be inspected/observed with long intervals in between. No one is going to remove the tank to inspect for tightness on a regular basis. Too lose and the threads just may come out with the plug.
Old 01-06-2020, 05:46 AM
KrustyKush's Avatar
KrustyKush
KrustyKush is offline
Mine were loose on 2018 FLTRU... I'm pretty sure this is assembly problem at the factory, because after I installed new plugs and torqued to spec, they have stayed nice and snug ever since.
I don't have a complaint about needing to remove the tank to access the two inner plugs. I tend to replace my plugs every 10-15k anyways. 30k does seem like a very long time.
Old 01-06-2020, 07:06 AM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,262 Likes on 3,416 Posts
3K, mine were tight.
I took note as I scattered the engine.
Quick Reply: Spark plugs loose? Yes
