Spark plugs loose? Yes
Old 01-09-2020, 10:50 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 30,900 Likes on 11,613 Posts
Anyone tried to change plugs on a modern car V6. I’m not even sure mine has plugs.
  #32
Old 01-09-2020, 11:19 PM
TriGeezer's Avatar
TriGeezer
I’ll be pulling the tank to run some wires. I’ve got 20,000 miles. While it’s off, I guess I’ll change out the plugs.
  #33
Old 01-10-2020, 05:57 AM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,264 Likes on 3,417 Posts
Originally Posted by MTBIG G
I second that, but changing all 4 plugs on the m8 is fairly quick and easy as well. Only takes about 1 hr... if you're slow.
Yeah, not bad at all. I rate it a 2 beer procedure.
  #34
Old 01-10-2020, 06:58 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,481 Likes on 761 Posts
As I recall, my 67 Sunbeam Tiger had access holes in the firewall to get at the two rear plugs from inside the car. Did I bitch about it? hell no. Many folks will never get enough miles on their beloved Milwaukee Eight to change the plugs anyway. Lol
The following 2 users liked this post by sixguns:
Silentgreyfellow (01-10-2020), touchdown (01-10-2020)
  #35
Old 01-10-2020, 07:08 AM
deckdr's Avatar
deckdr
deckdr is offline
Default Wow, another helpful comment!
Thanks for sharing your cheerful attitude!
  #36
Old 01-10-2020, 07:32 AM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 3,152 Likes on 1,859 Posts
LOL I was just thinking about when I change all SIXTEEN plugs in my Ram's HEMI... Talk about a PITA to get to.
On these bikes, 4 bolts, a fuel line coupling, and two electrical connectors is not rocket science nor a headache.
  #37
Old 01-10-2020, 02:09 PM
SEFast's Avatar
SEFast
SEFast is offline
Decided to knock out the 10K service at the same time that I was installing a few accessories. Pulled the tank to install the 10mm Phat Plug Wires and noticed the top rear plug hole was completely white. Pull the plug wire and found the spark plug was loose enough to be remove with only my fingers. Inspected the threads and everything looked ok, but decided to change them out anyway. Better safe than sorry!
Speedy
  #38
Old 01-10-2020, 04:26 PM
Skayy's Avatar
Skayy
Skayy is offline
Speedy
i'm wondering if you had spark knocks (pinging when accelerating) with that?
Thanks Kai
  #39
Old 01-10-2020, 05:40 PM
Issysportster's Avatar
Issysportster
Issysportster is offline
This thread inspired me to check my plugs on my 19 Sport Glide. They were not finger loose, but they were not tight either. The right side plugs were more loose than the left side plugs.
An added note...you do not need to take the tank off for the Sport Glide or the Street Bob.
  #40
Old 01-10-2020, 06:47 PM
19special's Avatar
19special
19special is offline
Good deal, and no chance of ruining the O-ring. LMAO
Quick Reply: Spark plugs loose? Yes
