GTS radio arrived for GT swap but USB cable delayed
Just curious... does anyone know....
I've looked at adding the GTS to my 2016 Ultra Classic.... but I use a thumb drive, plugged into the USB cable for all my music...
Does the new GTS still allow for that? Or is it strictly set up for all the cellphone carplay/android audio type stuff...?
Thanks for any insight...
hattitude (12-19-2019)
hattitude (12-20-2019)
I installed the new GTS radio in my 2017 StreetGlide. I had brought it to the dealer to get the system enabled. I had them enable the WHIM feature but forgot to ask them to disable the microphone in an attempt to get Apple CarPlay to work. No luck the CarPlay didn’t work. It was recommended to me to try to do a system reset...pre calibration reset in the service menu to see if it would possible help with getting the Apple CarPlay to work. Here is results:
Did it work when you left the dealer after they flashed/enabled the system. I do not have the new gts on my 17 but had thought down the road, I may do that. Would seem like if it worked when you left dealer gotta be something simple. Hope you find an easy fix to get this going, doubt a connector would do it, but might make sure everything is connected correctly, tight, etc.
Today’s findings with the new GTS.
installed the GTS in my ‘17 CVO SG, used existing cable, and existing XM module.
Booted radio and the boot up screen even showed CVO, which surprised me, using Diag4Bike set geographic location to N America, enabled the WHIM, enabled all the necessary functions and viola, Car Play works, Siri works, Sirius XM works.
I learned that the only difference in the newer part number for the USB cable could be and most likely, a supply vendor change and HD will identify that with either a new part number or a revision letter.
Here to tell you the cable and the Sirius/XM module work fine.....
what HD dealer can’t do using DigiTech, as in making CarPlay work w/o the actual WHIM and all, Diag4Bike can.
The following 2 users liked this post by GlidingJoe:
Cosmic Razorback (12-31-2019),
Old Sport (05-03-2020)
