Oil pump issues with 117 Milwaukee 8's .
When I have a new problem I always check the last thing I did to the bike. If there was no sumping problem before the cam and oil pump install, there is most likely a problem with the pump or it's installation. Feuling recommends installing the oil pump attached to the cam plate. I didn't do mine that way because it seemed to increase the possibility of the O rings not being properly seated. I installed the pump and then the plate. All I know is mine works fine doing it that way. I know this ain't your first rodeo, but most of us have had a bad day, just missed seeing something, or just bad luck. I'd tear it down and check the O rings and reinstall that oil pump. Good luck!
