Hydraulic Clutch adjustment
Old 08-24-2019 | 12:50 PM
TexasScott's Avatar
TexasScott
Just ask him to be sure to check the Blinker Fluid
Old 08-26-2019 | 07:11 AM
jake24lt's Avatar
jake24lt
The only thing they adjusted, was the size of your wallet bearings!
Old 08-26-2019 | 07:25 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by 702
The hydraulic clutch is not adjustable.
So they removed the clutch adjustment under the derby cover? Seems odd...
Old 08-26-2019 | 07:38 AM
702's Avatar
702
Old 08-26-2019 | 09:11 AM
Keithhu's Avatar
Keithhu
Its not odd in any way. They didn't remove anything, its hydraulic vs mechanical, so its different. Do you "adjust" your brakes?
BrandonSmith (08-26-2019)
Old 08-26-2019 | 11:25 AM
Tom84FXST's Avatar
Tom84FXST
I have an aftermarket hydraulic clutch, that still has the clutch adjustment in the primary...I can adjust the distance from the bars that it engages in seconds...so it seems odd...
Bet the aftermarket comes up with an adjustment for that in no time...not everyone like their "zone" the same...
Old 08-26-2019 | 12:45 PM
Keithhu's Avatar
Keithhu
In no time? Hydraulic clutches have been on M8's for 4 model years now. Longer for CVO's. I guess if you're a tectonic plate, this wait amounts to "no time"
Old 08-27-2019 | 08:15 AM
Tom84FXST's Avatar
Tom84FXST
An adjustment to control where the hydraulic clutch engages has been out for a while...guess I don't have to wait on them tectonic plates...
madmat (08-28-2019)
Old 08-27-2019 | 08:17 AM
Keithhu's Avatar
Keithhu
Fine, but you're not adjusting the clutch, you're adjusting the lever.
madmat (08-28-2019)
Old 08-27-2019 | 09:00 AM
K Melancon's Avatar
K Melancon
That’s not a clutch adjustment. The clutch works exactly the same no matter what position you put the lever. Thats for the reach for those with little hands.
John_HD
11
10-08-2010 07:53 AM
Gary7
02-09-2009 11:37 AM
wrobo13
05-21-2008 10:51 AM
allenp99
04-25-2008 03:56 PM
HDHoosier
02-05-2008 06:46 PM
Quick Reply: Hydraulic Clutch adjustment
