Loss power and oil loss
Old 06-23-2019 | 04:12 PM
Shahin7497's Avatar
Shahin7497
Default Loss power and oil loss
This is the second time oil temp was over 300 and no oil on dip stick. Plus this time bike wouldn’t start until I put a quart of oil in. The bike would suddenly cut of at her I started it. My average temps are 250.since I have a stage 1 with power vison, my bike has been tagged for tuner. Took the bike out for few hundred miles today no issues. Now debating on a fueling oil pump?
Old 06-23-2019 | 06:37 PM
Neil's Avatar
Neil
I would find someone with a bore scope and check the cylinders. Sounds like the motor is sumping. Unless you are burning oil the oil is most likely still in the crankcase and you are now a quart over filled at least. High engine temp, loss of power and low oil level are the prime symptoms. If things got that hot I'd be afraid you burned up a cylinder or two. Good luck.
Neil
RDMC
Old 06-23-2019 | 09:15 PM
hdrider1's Avatar
hdrider1
Hope you're sumping isn't caused by a loose piston oiler jet. Mine sumped twice within 1,000 mi before the piston jet broke a tooth on the counterbalancer and destroyed the engine. If it's a piston oiler jet issue you'll have a ticking time bomb that won't get fixed with an oil pump.
Old 06-23-2019 | 09:35 PM
Shahin7497's Avatar
Shahin7497
Default Oil loss
It runs great except 2 times where I can tell loss power in 2nd gear.no noise at all, runs good today with oil temp around 250. Only issue is I have been tagged for power vision I have stage 1 114 rg
LeadDoggy
Engine Mechanical Topics
11
06-25-2018 09:17 AM
dammitman88
Exhaust System Topics
13
08-19-2012 08:46 PM
fireaxxe
11-20-2010 01:15 PM
bigmikaele
04-06-2010 04:26 PM
DevilDog3
Oil Archive (no new posts)
06-14-2005 08:42 AM
Quick Reply: Loss power and oil loss
