Pushing up stock Rk handle bars
Old 06-03-2019, 07:56 PM
Silentgreyfellow's Avatar
Silentgreyfellow
Silentgreyfellow is offline
Originally Posted by DenisLM
Mine was a world of difference when I got it aligned with the shocks. i can go for hours riding and no problems.
Nice ride. I'll give moving them up a shot. I've got nothing to lose.
Old 06-03-2019, 09:54 PM
h7009's Avatar
h7009
h7009 is offline
I have a Road King standard. I put a 3 1/2" riser on mine, looks great and I ride very comfortable. Whole set up was about $105, risers, new cover plate, and cover for handle bars. Good luck, CSM-H
Old 06-04-2019, 10:43 AM
mbco's Avatar
mbco
mbco is offline
I pushed mine forward in line with forks as well. I hadn't thought about risers Can you provide more information and maybe some pics? Did you need to do anything with wires and lines?
Old 06-05-2019, 11:58 AM
Silentgreyfellow
Little update. I moved the bars up like DenisLM did inline with the forks. They feel better and my arms and wrists are in a straighter postion. Just need some better weather to try it out in the road. Thanks for the input guys.
Old 06-06-2019, 08:57 AM
h7009's Avatar
h7009
h7009 is offline
Default Risers on a Road King
mbco, using the "Fat Book", ordered the 3 1/2" straight risers ( $49) , a new "plate" ($50) to cover the area where the risers originate from and a new handle bar cover ($20). So closer to $120. Need no wire extensions, just cut the wire clips (zip ties). Took me about 1 1/2 hours and that was going slow!! Good luck, CSM-H
Old 06-08-2019, 08:11 AM
Ericson38's Avatar
Ericson38
Ericson38 is offline
What is the Fat Book ? Googled it along with 3.5 inch, could not locate it for Road King. Are these HD items or JP Cycles ? Thanks.
Old 06-08-2019, 08:30 AM
Silentgreyfellow
The fat book is what Drag specialties calls there big catalog.
Old 06-08-2019, 09:49 AM
Ericson38's Avatar
Ericson38
I'm looking for a vertical extension (rise) of about 1.5 to 3 inches, and would like to keep the tachometer and key cover and Road King Police badge where they are on the FLHP.
Old 06-10-2019, 08:11 AM
h7009's Avatar
h7009
h7009 is offline
Default risers on Road king
Ericson38, Not sure where those items are placed. I replaced the "cover" where the stock (very short riser is), mine is chrome. Put in three and 1/2 risers (1 1/2 will not work!!) Used a new cover clamp piece, you could probably use the sock one, not sure. Bars are a little back from vertical but about 3" higher. I like it!!
Old 12-05-2019, 02:13 PM
eddie31770's Avatar
eddie31770
eddie31770 is offline
Originally Posted by bads1buell
I tried it on mine and it was worse. ended up moving them back to stock position. I think they have a weird wrist angle and are too narrow. Trying to decide on which bars to get. Apes or a beach bar style...
I have the same issue with my '18. Too close in stock position and bad wrist angle when I moved them up. I ma 6'4" with a mustang super touring seat. What did you end up doing with your bars?
Quick Reply: Pushing up stock Rk handle bars
