M8 burned up clutch
You replace the factory clutch rod with an aftermarket clutch rod that's machined to be much thicker than the factory rod. This new rod fits in the hole perfectly whereas the factory rod has a ton of slop where the fluid bypasses and goes into the primary.
Everyone who's installed a fat rod says it works perfectly.
