Breather Question I haven't seen addressed before
After seeing the amount of oil sitting in the intake and air filter I am thinking about doing a breather bypass. I do not fully understand the dynamics of the breather system so I want to ask a question. For those that know everything please humor me if this is a stupid question.
My understanding is the breather system is used to remove the built up pressure due to ring blow by. What I don't know is if the pressure in the crankcase pushes all the gasses out or if there is a vacuum created since the discharge tube is in the intake pulling the gasses out or a combination of both.
And the main concern is, if it is a combination, does running the discharge to atmosphere change the dynamic and could this in any way be related to the sumping issue? I also have to assume the system is designed to handle a specific amount of blow by. Could changing components and increasing piston size, reducing intake resistance etc. be related to the sumping issue.
And for the record, I have a 17 SGS and have not had any sumping or transfer issues in 10000 mile and want to keep it that way.
about all I can offer is on this issue is that after we updated the SE High Flow AC breather tubes to their reconfigured ones that reposition them into the intake further the excessive combustion residue has made its way into the intake more effectively as it is designed to, instead of dripping down the backplate and onto the filter causing external messes. some folks can't tolerate this epa design and opt to use a catch can or vent to the atmosphere but I don't believe it's a significant enough amount to cause engine problems
My understanding is that the breather system is used to remove the accumulated pressure due to blowing. What I do not know is whether the pressure in the sump pushes all the gases out or whether there is a vacuum created since the exhaust pipe is in the inlet pulling the gases out or a combination of both. are related to the summation question?
