2019 Road King in shop w/Sumping
#41
Look how thin that case wall is.
Note the two part gear on the balancer. Its like what Mazda did with their cam drives. Both gears have a different number of teeth so they rotate at different speeds, one being fixed and the thin one not. The gears will have a friction plate between them and its designed to keep lash at zero so there's no noise. Could be wrong but thats what it looks like.
#42
#43
#44
Where you seeing a two part gear? I see one on the counter balancer, and one on the crankshaft. From other pictures those are the same size. Considering the balancer's location, they would have to be, or at least some fraction of size such that the counter weight NEVER strikes the crank pin. The counter weight only has a specific range of time it is allowed to swing between the flywheels, not like the TC-B motor where the counterbalancers have their own little universe to spin around in.
#45
#46
#47
It has to have a different number of teeth to function, you dont understand the concept. I was just making an observation. Back to sumping!
#48
I'm liking this dealer more every day. I texted the tech this morning saying I wanted a new oil pan. He immediately texted back saying I get a new pan and oil cooler.
The following 8 users liked this post by hdrider1:
Don Michigan (04-14-2019),
G'day (04-12-2019),
hattitude (04-06-2019),
MTBIG G (04-05-2019),
RinTin (04-05-2019),
and 3 others liked this post.
#49
If you look at the countershaft gear you'll see a parting line and the teeth dont align. If its what I think it is, its there to prevent noise from lash, keeps the gear loaded so it can't fluctuate. The two parts move independently and are only connected through friction.
#50
It's called an anti-backlash gear, one right next to the other, and one is spring loaded to make it offset from the other to reduce backlash. The offset is consistent for each tooth around the entire gear. When it's mated to the crankshaft gear everything lines up perfectly like nature intended. If the spring loaded gear had less teeth, this would cause the distance between the two gears teeth to vary around the whole gear assuming they were the same diameter. (a gear of lower diameter would be pointless, obviously)
Here's a larger one to show the teeth
