M8 Dyno Numbers
Old 02-16-2021, 08:51 AM
AmericanClassicMotors's Avatar
AmericanClassicMotors is offline
Former Sponsor
Top is a Bagger, Below is a Softail.
Jim
Originally Posted by yobtaf103
Are these softail or bagger builds ?
yobtaf103 (02-16-2021)
  #472
Old 02-16-2021, 08:55 AM
Former Sponsor
Nice 107" M8 Bagger from last week with a Zippers Performance Redshift 472 Cam.
Jim
  #473
Old 03-22-2021, 11:09 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,165 Likes on 1,357 Posts
Great build we did last week for HDF member batouttahell with the Wood WM8-22XE cam. Total torque monster; bike makes almost 150Tq at 2500 RPM.
2019 Road Glide. FM 128" big bore, Wood WM8-22XE cam, stock heads, SE 64mm Tb w/Ward manifold, FM AC/DC air cleaner, Jackpot RTX 2/1, tuned with Dynojet Power Vision
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The following 3 users liked this post by fuelmoto:
johnnynitro (04-05-2021), NorthWestern (03-23-2021), RGS88 (04-02-2021)
  #474
Old 03-22-2021, 11:27 AM
Outdoor Family's Avatar
Outdoor Family
Outdoor Family is offline
Default Hard to compare
Dyno numbers are hard to compare. If you are not worried about your warranty. My bike is still in warranty so have to use all screamin eagle parts and tuner. Once the warranty is up should be a big increase. I has the 131 kit put on my bike. REALLY woke it up. Dyno was 131hp 138tq all within warranty and EPA.
William Ferril (01-10-2022)
  #475
Old 03-22-2021, 02:36 PM
JETRO's Avatar
JETRO
JETRO is offline
Stage III
Here's my sheet from a 131 with woods 22xe, fulsac head pipe, tts tuner s&s pump and plate. It runs strong in the short distance I've run it. A little flat spot off idle that needs to be sorted out but otherwise runs real good.
  #476
Old 03-23-2021, 07:34 AM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Veteran: ArmyVeteran: Navy
Received 6,565 Likes on 1,811 Posts
Simple stage 2, 2017 RG with stock intake, stock head pipe w/cat, Cobra slip-ons, and RS468 cam.
fuelmoto (03-23-2021)
  #477
Old 03-27-2021, 06:02 PM
davidslimm's Avatar
davidslimm
davidslimm is offline
1st Gear
Default Stage 2 107 roadglide
2020 roadglide 107 power dual header, mk45 slip on, extreme heavy breather, s&s 475c cam 114/118
  #478
Old 04-02-2021, 04:56 AM
Bigdaddyhas2's Avatar
Bigdaddyhas2
Bigdaddyhas2 is offline
Stage II
Default 2019 roadglide
135
MHD Devil runner, 162hp 152tq
The following 7 users liked this post by Bigdaddyhas2:
b1kecrazy (04-02-2021), cvosjoe (04-02-2021), FLSTFI Dave (04-04-2021), Hairy Larry (04-07-2021), Mofo67 (04-02-2021), RGS88 (04-02-2021), Teknition (05-05-2021) and 2 others liked this post. (Show less...)
  #479
Old 04-11-2021, 05:19 AM
OldMike's Avatar
OldMike
OldMike is offline
Received 1,927 Likes on 1,260 Posts
Default 2020 131" Low Rider S
SE Extreme CNC Ported Heads 16500750
SE 4.310 Big Bore Cylinders 16800210
Jims V-twin Perf. 11.4:1 Pistons
Max-Cell M837B Cam, .550, 35 I.C.
S&S Roller Rocker Arms
SE CNC 64mm Intake Manifold
SE 64mm Throttle Body
Jims V-Twin Perf. 8.2 Injectors
Feuling Race Series Lifters
SE Ventilator AC w/STFU Filter Mod
Power Vision Tuner
Thrashin Supply AR Exhaust, 1960-0 baffle
Rekluse Torque Drive Manual Clutch
TTS M8 Tool Steel Compensator
The following 4 users liked this post by OldMike:
FLSTFI Dave (04-11-2021), Hairy Larry (04-11-2021), NorthWestern (04-11-2021), yobtaf103 (04-11-2021)
  #480
Old 04-15-2021, 02:34 PM
yobtaf103's Avatar
yobtaf103
yobtaf103 is offline
2020 Fatboy
FM "A" Heads
Jims V-Twin 128 cyl kit 11.2:1
Jims V-twin Max-cell 837B cam
6.2 inj
Ward 64mm cnc manifold
SE64mm tb
Jims V-Twin lifters
SE Extreme ventilator - external breather
Tuner -Direct Link
Thrashin Supply AR 2-1 largest Dogball option
AIM SDR /springs
TTS (UK) steel comp ramp
The following 2 users liked this post by yobtaf103:
FLSTFI Dave (04-17-2021), OldMike (04-15-2021)
Quick Reply: M8 Dyno Numbers
