M8 Dyno Numbers
#421
2019 Road Glide, FM 124 big bore kit, WM8-22XE cam, with stock heads & throttle body, FM 5.5 injectors, and he's running a Vance & Hines Pro Pipe 2/1 and Dynojet Power Vision
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#422
The following 4 users liked this post by Steve Cole:
#424
Will there be any updates to include 131 maps for a 2020 touring oil cooled tts 250 cam be included in the Mastertune software library some time soon.
#425
#426
#427
124 with RS 468 cam
2017 FLTRU - Fuel Moto 124cu. 10.75:1 Compression Ratio, Stock Heads, 64mm SE TB and Manifold, Fuel Moto A/C kit, Red Shift 468 cams, zero decked, Decat Headers with S&S 4” Grand Nationals, Feuling Race Plate and Oil Pump, Feuling 6.1 g/s inj. Tuned by Prestige Custom Cycles in Elmsford, NY. Red is FM map ans Blue is corrected tune.
William Ferril (01-10-2022)
#428
#429
Happy with the torque curve but not the numbers. The numbers above is what most dynos have with this cam on a 107. Idk whats the issue with the amount of parts in this build I should be running north of 130s in torque and at least 118hp. I will talk to FM and ask them their opinions. The dyno was saved on my powervision map so they can take a look at the runs themselves. But a 124cubes should not have 119 lbs of torque peak no matter what cam or compression.
Xcrossbow (11-06-2020)
#430
