M8 Dyno Numbers
#301
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#302
#303
Engine build specs.
2017 FLTRXS
S&S cylinders (4.280)
Mahle pistons (4.280) with APC coating
12.1:1 compression
HD Street Performance heads (stock valves)
Rocket 544 cam
Woods Alpha series lifters
HPI 62 mm throttle body with 6.1 injectors
D&D Billet Cat with 2.5" Vortex baffle
Adjustable rockers
Zero deck
Lifter cuffs
8 lobe pump assembly
10 disk updated clutch
AIM SDR with heavy springs and 2 shims
Power Vision
Even with the heavy springs and shims the clutch started slipping around 2500 and didn't settle down until the AIM SDR started to kick in a little over 3200.
2017 FLTRXS
12.1:1 compression
Rocket 544 cam
Adjustable rockers
Zero deck
Lifter cuffs
Power Vision
The following 3 users liked this post by cvosjoe:
#304
Engine build specs.
12.1:1 compression
Rocket 544 cam
Adjustable rockers
Zero deck
Lifter cuffs
Ruff
12.1:1 compression
Rocket 544 cam
Adjustable rockers
Zero deck
Lifter cuffs
Ruff
What tuner? How are the street manners? What year, model Harley? How many miles on it since the build?
Thanks
#305
Power Vision tuner.
I'm picking it up tomorrow from the tuner. Only has a few hundred miles since the build. Was easy to ride before the tune. The tuner says it has great street manners when he test rode it.
yobtaf103 (12-05-2019)
#306
#307
#308
#309
#310
Jamie at Fuelmoto has said that he had trouble with clutch slippage on high torque motors when he used primary lube that had synthetics in it. It might be worth checking if what you're using has synthetics. Something else that might help is the Rekluse Torq-Drive clutch. It has 15 friction plates and you can use the SDR with it. Might be worth considering.
