M8 Dyno Numbers
Old 05-05-2019, 09:09 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,854 Likes on 1,001 Posts
Originally Posted by 3dognate
2017 Road Glide Special > SE Heavy Breather Intake + D&D Billet Cat Exhaust + Red Shift 468 cam + DJ Power Vision tuner = 96.9 hp / 111 ft lb torque.
I am picking up my RGS a little later today I got the call yesterday that my bike was ready from it's tuning session. I used Coziahr Harley-Davidson in Forsyth, IL for tuning. Admittedly was expecting slightly bigger numbers considering what some of you are getting with similar results. But that's still a 23%+ increase over stock. I'll post the graph later assuming I get a copy.
I also have a V&H FP3 tuner. I might get froggy and flash a base map and run an FP3 Auto tune and see if the old butt dyno can tell the difference between the two.
Just remember a dyno is just a tool for tuning. They all read a little different and there are things that can affect the numbers they are putting out, it doesn't mean the bike isn't making the same power a different bike is with a similar setup on a different dyno giving higher numbers. Also, if it is not a Dynojet dynamo meter it will have an even greater chance of putting out different (lower) numbers than a Dynojet. Dynojet dynos are actually generous on their power figures, it is designed into them. I can't remember the reason for this, but I know I have read about it.
  #102
Old 05-05-2019, 10:33 AM
Tn.Heritage's Avatar
Tn.Heritage
Tn.Heritage is offline
Here is tune just done a few days ago from J&B Performance with RS472 cam, I think it's still a 2-1-2 system with Bone Shaker mufflers, basically CFR's really. Anyway, hurt the bottom end a bit but really good numbers.
  #103
Old 05-05-2019, 02:50 PM
Alexspain's Avatar
Alexspain
Alexspain is offline
124 FM head pipes FM, Heads ported by FM, S&S465, SE 64, Heavy Breathes extrem, injectors 5,5 , Kessthech.
  #104
Old 05-05-2019, 03:08 PM
3dognate's Avatar
3dognate
3dognate is offline
***Update with Chart***
  #105
Old 05-05-2019, 09:23 PM
3dognate's Avatar
3dognate
3dognate is offline
I got out and did some riding after picking up the bike and posting that chart. I'm not terribly pleased with my tune... it's running hot and cackling on deceleration it even full on back fired a couple of times. It's going to have to go back for another round... the shop does good work as a general rule so I'm sure they'll make it right. They even expressed after my initial reaction that it didn't "feel" right to let them know and they'd give it another session. So I'm calling tomorrow to arrange it to go back for a more thorough session.
  #106
Old 05-06-2019, 04:40 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,608 Likes on 2,727 Posts
It really baffles me why tuners create charts this way with 2 different axes. Makes no sense, and honestly, it makes me question their skill and/or motivation. When I look at this chart, looks to me like the TQ and HP drops off very early
  #107
Old 05-06-2019, 05:16 AM
Tn.Heritage
Not trying to rub salt in the wound but here's a 468 that J&B did, this will give you something to compare too.
  #108
Old 05-06-2019, 07:45 AM
3dognate's Avatar
3dognate
3dognate is offline
That's a 114" but I get the point.
  #109
Old 05-06-2019, 08:01 AM
$tonecold's Avatar
$tonecold
Comparing 114" CVO to a 107 is kind of apples and oranges.
The RS468 is not an easy cam to tune, but if it is done correctly it gives excellent results. Give them another chance, but if they don't get it right the second time find someone else. You have a setup that should yield good results. Here is the graph of my bike with the RS468 cam.
With the BilletCat on your bike the torque should come up quicker than mine, although it might not get to 120 ft/lb. If you get to 115 or 116 ft/lb you're in the range. Here's Zipper's chart with the RS468 and BilletCat.
If they get it right it will be a blast to ride! Good luck!
  #110
Old 05-06-2019, 08:18 AM
Quik's Avatar
Quik
Quik is offline
Received 2,577 Likes on 1,527 Posts
Hey stone,
I don't have full confidence in the shop that's gonna dyno my bike after the cam, you say the 468 is not an easy cam to tune, you and I have talked about the ss475 in my cvo 117, how do you think it will tune if I leave the cat in the stock pipe and my magnaflow mufflers, they prefer TTS so that's what I bought.
Quick Reply: M8 Dyno Numbers
