2019 SGS and Ohlin Shocks - advice
Old 02-03-2019, 09:50 AM
JHC210's Avatar
JHC210
JHC210 is offline
Default 2019 SGS and Ohlin Shocks - advice
I purchased a set of Ohlins #2-#2A from Howard and running them on a 2017 Limited Low. I may upgrade to a 2019 SGS. Would the same shocks work on the 2019 SGS? I assume so as I believe the 2019 SGS have 12" shocks. Thoughts?
Old 02-03-2019, 09:58 AM
Softy 103's Avatar
Softy 103
Softy 103 is offline
I would think they would work, but if your 2-2As don't ride any better than my 2-2bs did then I would just run the shocks that come on the 2019. Just my opinion, and my wife even says the new bike rides just as good as the 2012 did with the 2-2bs.
If I venture out into the aftermarket for shocks again it will be Pro-Action.
Old 02-03-2019, 10:05 AM
JHC210's Avatar
JHC210
JHC210 is offline
My 17 had the hand adjustable "premium" shocks but they were bad. Ohlins made the ride really enjoyable. The 19's have a better premium shock?
Old 02-04-2019, 12:16 AM
SomeOld Biker's Avatar
SomeOld Biker
SomeOld Biker is offline
I hear Legend A's shocks are pretty good too.
Old 07-02-2020, 08:42 AM
btsom's Avatar
btsom
btsom is offline
"Ride like crap" lacks some degree of precision. Are they now too firm and rough or do they bottom too easily? How are they different from the factory shocks you removed to put these on? For HELPFUL suggestions, precise information is needed. This is not much different from the classic: "My bike won't start, what is wrong with it?"
Old 07-02-2020, 02:47 PM
teedoff65's Avatar
teedoff65
teedoff65 is online now
Received 1,497 Likes on 1,075 Posts
I'm trying to find where anyone says "ride like crap" lol
I upgraded to ohlins rear shocks on my 17 rgs. Made a good improvement. Just test road a 2020 3 weeks ago and while it road good, I wasn't willing to give up my ohlins even though I thought they were a little unimpressive. But now that I have them on the new bike, after test riding it, I can tell the difference. I dont feel those "every little bumps" in the road like I could with stocks. I think suspension is one area thats worth the upgrade.
Old 07-06-2020, 09:44 AM
jmd897's Avatar
jmd897
jmd897 is offline
It could be the spring too hard. I had that issue and Howard swap them up and rides excellent
Old 07-06-2020, 09:49 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,650 Likes on 3,855 Posts
What springs did you end up with? If you don't know for sure you can read the number off the spring.
Old 07-06-2020, 12:54 PM
mikes300's Avatar
mikes300
mikes300 is offline
yes they will bolt right on. my 18SGS had the premium shocks,I put on the Ohlins 772 blacklines, night and day better!
Alexspain (07-08-2020)
Old 07-07-2020, 06:53 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 5,901 Likes on 3,207 Posts
Those are the ones I was just looking at. Pretty sure that is the way I am going.
Did you do the Ohlins fork upgrade as well?? Can't find a ton on this, for newer baggers anyway.
Thanks!
Quick Reply: 2019 SGS and Ohlin Shocks - advice
