Installing Road king bars on a RG
01-02-2019, 03:02 PM
The RK bars are 1" and the RG are 1 1/4", so I was wondering should the wires be inside the bars? Any tips on removing the wires from the connectors. Any other tips and tricks would be great! Thanks, Dave.
01-03-2019, 10:47 AM
You'll need different clamps as the RG bars are 1 1/4 where they clamp onto the trees, why not just get bars made for a RG.
01-03-2019, 11:09 AM
Yes, you'll want to run the canbus wires through the bars. Make sure your new bars have the holes required to do that.
I picked up an OEM 1" clamp off ebay for 22 bucks.
01-04-2019, 03:00 AM
As was asked earlier, why not get the bars for your bike? Will make it easier to run the wires through
01-05-2019, 06:33 PM
I liked the RK bars on my old RK. I thought it would be a easy swap. Wires for the throttle thru the bars no doubt. Other wires from switch pack can be on outside. I thought the bar clamps were 1" on the RG...
01-05-2019, 08:12 PM
Better check your hydraulics' clamps. The taper at the end of the bars is different between the RK and RG bars and require different clamps.
fuel injected
01-18-2013 11:52 PM
eazyrider
09-14-2009 03:13 PM
08blacksporty
05-21-2009 11:00 PM
RoadKingRon
04-08-2007 04:59 PM
REDROADKING
04-27-2006 10:15 PM
