Boom audio question
Boom audio question
I have never had a headset on my 17 RG. I see that there is a simple plug in for adding a plug in for a headset. Is anyone running with JUST a mic to be able to use the call features with the boom audio. I really do not want anything but the mic. I can hear through the bikes speakers.
Here's why: The handlebar switches are all CANbus (digital addressing) which is how the 6.5GT receives its' inputs. The headset jack is NOT WIRED for the PTT function. The mic itself uses a multi-contact switch to switch between transmit & receive functions using old hardwire contacts. That's needed to complete the mic audio signal path (this can be modded to avoid the need to depress the mic's PTT switch). Then the handlebar PTT switch sends the digital signal (via the switchpack module it's mounted in) to the radio via CANbus to accept/use the audio from the mic.
This is something I discovered on the day I purchased my '14 Limited (tried to retain/use my hand mic from my '07 Ultra). And, I only tried to use it with the CB, not with the Voice Command. So, if the need is only to use the Voice Command function, modding the mic to keep its' PTT switch depressed may work well if you can depress the voice feature, then pick up the mic during the audio prompt & speak your audio command. And, in theory, the handlebar PTT doesn't need to be added for bikes that didn't have that switch as oem.
dcfatboy (12-29-2018)
Here's the Mic interface I built for the 7-pin DIN connector. DIN to F3.5mm, and M3.5mm to Microphone. I also created a "Dummy" 7-pin DIN that I hope will fake CarPlay into thinking there's a Mic attached. I have yet to get to my Dealer to be able to play with these toys.
My 3 issues with the Boom system on my 17.
1. The speakers sound shitty. You can buy good sounding speakers for next to nothing. For what a headset costs you would think the quality would be better.
2. Which should be number 1. The cables and having to plug into the bike.
3. The VOX system sucks. Pass a truck and it activates. Go over 65 mph and you have to set the sensitivity to a point that it won't activate when you talk.
Another $1000 for the SENA system??? And have similar problems.
Works on my '17 CVO and my buddies '14 Ultra,
https://www.ebay.com/itm/THE-FREEDOM...76N:rk:27:pf:0
I use this and it does exactly what your looking to do.
I think I found exactly what I am looking for. probably gonna end up with a 200+ buck bill in the end. I am getting the standard HD plug in kit with this headset.
https://www.harley-davidson.com/stor...MGTA&gclsrc=ds
I looked at the blue tooth wireless set up and honestly I just don't see the value in that. 300 bucks for the adaptor and another couple of hundred for the headset? I mean I enjoy blue tooth, but honestly double the price of a wired connection? naw I seriously do not see the value in that at all.
