Slave cylinder replacement
Old 10-31-2018, 04:08 PM
JohnTz's Avatar
JohnTz
JohnTz is offline
Default Slave cylinder replacement
Can someone who has done this job please comment if the exhaust needs to be removed? Specifically can the transmission outside cover be removed without removing the exhaust? Stone? Steve? Your experience would be greatly appreciated.
Old 10-31-2018, 04:21 PM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,801 Likes on 965 Posts
You will have to take the exhaust mounts (right side motor and back of transmission) loose and loosen the flange nuts at the ports, then you should be able to pull it out enough to get the cover off. If not, take the muffler to saddlebag frame bolts out on the left side. That will give you a little more play.
Old 10-31-2018, 04:24 PM
JohnTz's Avatar
JohnTz
JohnTz is offline
Thanks Stone. What a pain in the ***. Lots of work to do to just get to the bleeder nipple.
Old 10-31-2018, 04:49 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
Us men go to great pains to get to the nipple!!! Cheers!
Old 10-31-2018, 07:15 PM
talkingrock's Avatar
talkingrock
talkingrock is offline
Yes the exhaust only has to be loosened so it will move out enough to pull the cover off
Old 11-01-2018, 12:53 AM
Sam2010's Avatar
Sam2010
Sam2010 is offline
Need aftermarket cover with a little trap door that would allow access. OR re-engineered totally look at all the recalls for various reasons from 14 until now.
Old 11-01-2018, 10:54 AM
JohnTz's Avatar
JohnTz
JohnTz is offline
I guess I will do this only once. Will run it without the cover or modify the cover so it comes off without loosening the exhaust. Too much work to simply get to the bleeder screw. I will install an AIM slave as well since I am on the recall list. May as well put a nicer slave in it while I'm at it. Waiting to see what some people say after getting the replacement if it makes a difference in clutch pull and where the friction zone is.
Thanks guys for your responses.
Old 11-01-2018, 02:29 PM
Bumpandrun's Avatar
Bumpandrun
Bumpandrun is offline
same boat....nothing wrong with mine but the AIM looks better quality. And one screw up at the dealer it's not worth the free warranty BS. Rather pay one time ..do it myself and be done. Was going to put a lift hand thread on clutch push Rod to see if my tiny amount of transfer stops( 2-3 oz in 5k) So it's coming apart anyway.
Old 11-01-2018, 03:55 PM
strych9's Avatar
strych9
strych9 is offline
Received 9,511 Likes on 3,607 Posts
You could always notch the cover and install a steel line to extend the bleeder port to external. I wouldn't do it, but it's an idea.
Old 11-01-2018, 06:46 PM
Bumpandrun's Avatar
Bumpandrun
Good idea. We do it on race cars all the time with hydraulic throw out bearings.....run the line out the bottom of blow shield ...
Quick Reply: Slave cylinder replacement
