Is my bike sumping?
Old 10-07-2018 | 03:55 PM
Jehu's Avatar
Jehu
Default Is my bike sumping?
I am of the belief that the sumping issue is not necessarily an all or nothing affair.
I am of the opinion that machines out in service may be sumping, but not so much that the critical symptoms are manifest significantly for rider diagnosis, noticeable power loss or, in extreme cases, catastrophic failures.
Based upon my "diagnosis" today, I invite the collective wisdom of the brain-trust here.
2018 FLTRX Road Glide 107" - bone stock.
2000 miles, broken in properly; 1,000 mile service done by me with appropriate components at approximately 800 miles.
Today I performed the following "test."
Engine warmed up and checked oil level. 3/4 of the way up the hash marks.
Rode the local roads to the interstate short shifting, as I typically do for the first few miles.
Ambient temperature was about 77 degrees.
Once on the interstate on-ramp, I went through the gears shifting at 3,500 - 4000 rpm then ran the livin' **** out of it for about 7 miles in sixth gear - 90-110 mph; then, due to traffic, had to slow to 80-85 for two miles but alternated between 6th and 5th gears loading the engine as much as possible when gaps in traffic permitted - all the while going 80-85 mph.
When I was close enough to a rest area I shut off the engine and held the clutch in. Because I accelerated to about 85-90 for the 1/8 mile approach, the heavy bike actually coasted pretty well. Once in a safe spot, I put her on the jiffy stand and checked the oil immediately and then a few minutes later. Both times it was at the half-way point (on average) of the hash marks. Later that day, running some errands and not riding nearly as aggressively, I shut down and checked the oil hot - it was at the 5/8ths point.
So, there seems to be about a 1/8th delta on the oil level between aggressive riding and "normal" for me - which is much more conservative.
Assuming the hash marked area is graduated to a quart, that 1/8th translates to 4 ounces of difference ... on top of whatever already may be in the sump normally. I don't believe the MoCo for one minute that [fill in the ever changing blank amount] is "OK" to be in the crankcase as it's just a shuck and jive - dodge the warranty, hide the problem for two years scam. The service bulletin threshold amount "OK to be in the crankcase" apparently has been upwardly adjusted as more and more "sumping bikes" became known. Classic example of "if at first you don'y succeed, change the rules!"
So, to those here that I trust much more than the MoCo (Mo-money Company) or, perish the thought, Stealerships,
I ask ... is my bike sumping?
Old 10-07-2018 | 04:39 PM
supernac's Avatar
supernac
Your always going to have a small amount in the sump, if you hit the kill switch a 5k rpm all of that residual oil is going to drain down into the sump.
Old 10-07-2018 | 05:14 PM
mazz's Avatar
mazz
i don't know **** about sumping, but i will say the manual asks you not to glide in with engine turned off i am no mechanic so i wont argue what it hurts or helps .but maybe 3 or 4 people on this site understand sumping others have opinions
Old 10-07-2018 | 05:39 PM
sixguns's Avatar
sixguns
The only problem with your bike is you. Lol
Old 10-08-2018 | 06:45 AM
Heatwave's Avatar
Heatwave
Member
The only way to confirm if your bike is sumping is to go out and ride it for an hr to 90mins with varying speeds and rpms. Then stop. Shut the bike down. Follow the instructions in SB1450. Measure the oil in the crankcase. Its relatively easy to do. If you have less than 6 ounces, your bike is fine. More than 6 ounces and your engine is sumping and it needs to be checked out by a dealer. Follow the instructions precisely in SB1450. Good luck. Hopefully your bike turns out just fine.
Old 10-08-2018 | 07:50 AM
Jehu's Avatar
Jehu
I question whether SB1450 can really be acurate given the variables.
What I tried to simulate was a best case scenario for sumping and worse case scenario for the gerotor's ability to purge/scavenge.
SB1450 allows for an engine to be ridden at modest rpm and load - using only temperature as the threshold to test. If the engine is at lower rpm the sump may have been evacuated or at least partially evacuated compared to WCS (worse case scenario). In fact, if a sumped engine is allowed to sit and then idles for a while - evacuation is the intended result. Moreover, the SB originally specified three ounces as the threshold and then was upped to six ounces. The whole affair raises more questions than answers.
Old 10-08-2018 | 07:55 AM
Heatwave's Avatar
Heatwave
Member
All very true. But if your intention is to make a warranty claim in the event your bike is truly sumping, you'll want to precisely follow the steps in the the latest Aug 2018 SB1450. Preferably letting your dealership do the actually measuring of the oil in the crankcase.
Old 10-17-2018 | 08:47 AM
Bumpandrun's Avatar
Bumpandrun
i believe the SB1450 was written for the goldchainers that threaten to take the MOCO to there knees. Lmao.....it's a Mickey Mouse test that keeps idiots busy( me 3 times till I learned it was a joke lol). Now forgotten.
Old 10-17-2018 | 12:17 PM
Wmitz's Avatar
Wmitz
I am going to add that having gone thru the sumping issues twice, it is very easy to tell. First, the exhaust gets louder, even in stock form. Second, the performance goes down the tube. Engine becomes sluggish on acceleration, engine braking/decel becomes greater, much more than normal. Third, engine heat, the engine gets hot, especially the rear exhaust pipe. And of course the burnt oil smell which can vary. After they replaced the pump the first time I couldn’t get the trike over 80mph, twist the throttle at 70 it took forever to get to 80. They ended up putting the plate and seal in before it went public. That seemed to take care of the issue, got rid of the bike for other reasons. Large amounts of oil in the sump will hurt performance, you can feel the difference.
Old 03-21-2020 | 03:36 PM
sbeamer's Avatar
sbeamer
When this happened, did the engine rpm change or not ?
Quick Reply: Is my bike sumping?
