Ecm reset ?
09-20-2018, 06:18 PM
Ecm reset ?
2018 M8 rgs , I want to go back to original ecm settings , with se tuner used to flash . Removing heavy breather and se muffs.
09-20-2018, 06:42 PM
Quote:
Originally Posted by
dastreetglide
Is there a question in there somewhere?
09-20-2018, 07:07 PM
Ecm
09-20-2018, 08:05 PM
dastreetglide
The SE Tuner has internally marked your ECM as "Tuned" so that will always be there from now on, unless you replace the ECM. Also the only way back to OEM tune would be to have the dealership flash the bike with a stock calibration as th eSE tuner will not do it.
09-20-2018, 08:12 PM
Not to hijack, maybe a little...
can the mothership detect the jailbroken se tuners or are they safe to use once they’re unmarried?
09-21-2018, 05:50 PM
Se tuner
Yeah id like to find that info to!! Moco has it all figured out . Crooks .
09-21-2018, 05:55 PM
Hd589
What is a jailbroken se tuner?
If you use a 3rd party tuner, (PV, FP3, etc), moco can detect that even if you flash back to the original map. Been discussed here 12 billion times.
09-21-2018, 06:04 PM
Some of us are just learning the hard way
09-21-2018, 09:02 PM
Keithhu
jailbroken means an se tuner that has been unmarried from the bike and brought back to virgin state.
12 billion and 1....
Sarge1
08-27-2018 04:57 PM
rvdoc
2014-2023 Touring Models
07-08-2017 08:54 AM
charloo
01-04-2013 02:32 PM
outgood
13
03-31-2012 02:53 PM
ambrose
01-15-2011 01:41 PM
