17 FLTRU Stage 1 and possibly Stage 2
After 1 year and 10k miles, I'm satisfied with my M8 and I'm ready for a stage 1 and possibly a stage 2. I've been working with FuelMoto and have narrowed things down to the following:
Stage 1
1. FM 2-1-2 ceramic coated head pipe
2. Either the FM Jackpot Outlaw, FM Hi-Rollers, or S&S Grand National mufflers
3. Power Vision (maybe with Target Tune)
4. Dyno
Stage 2
1. Woods 22X Cam
Before I pull the trigger I have a couple questions for the group.
1. Does anyone run the Outlaw, Hi-Rollers, or S&S Grand National mufflers? Since I use this bike for touring, I don't want something particularly loud. I'd like a little rumble like the HD Street Cannons when under throttle. Are any of my muffler choices going to be "loud"?
2. Does anyone have any experience with the PV and Target Tune? I'm on the fence about the Target Tune and wideband O2 sensors. They effectively double the cost of the tuning hardware and I'm not sure it's worth the expense. What are the communities thoughts?
3. Based on the dyno charts FM shared for a 107 M8 equipped with a similar exhaust and the Woods 22X cam it appears to put the torque right where I want it based on my riding style. Does anyone have experience with this cam?
4. Finally, if I do a cam upgrade does it make sense to replace the oil pump and the cam plate with either the fueling or S&S upgrades? I haven't had any sumping issues with my 107, but I'm not sure if I need to worry about it with the stage 2. Thoughts?
Thanks in advance!
Stage 1
4. Dyno
Stage 2
1. Woods 22X Cam
Thanks in advance!
I have 22x fuelmoto 2 1 2 header and high rollers.
they do get loud when you pass or run hard.
but when cruising they are not that loud,
fuelmoto has some dB reducers for the high rollers.
think they run about 40 bucks,I’m going to give them a try to see if they quit it down a little.
just a little too loud for me like they are.
Thought about stock mufflers back on to see how it sounds with the 22x cam,don’t mind loosing a little power if it will quite it down some.
As far as target tune,I think with a map from fuelmoto will have it so close I wouldn’t spend the money on target tune.
Now this is all my opinion so you may have a different idea how you want it to sound.
M8 sounds really good with cams and high rollers,and runs amazing with fuelmoto map in it with a couple of auto tunes.
Good luck with whatever you do.
intrepidxc (08-10-2018)
BigRed117
Milwaukee Eight (M8)
36
08-09-2018 09:58 PM
Dark Knight
05-11-2015 03:31 PM
