Installation of S&S M8 cam plate & pump
Old 07-02-2018, 11:21 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,167 Likes on 1,359 Posts
Default Installation of S&S M8 cam plate & pump
We are installing one of the new M8 cam plate & oil pump kits from S&S Cycle in a 2017 Road Glide. We're taking plenty of pictures and documenting the install. To get started we will post some images of the components we are working with. This is the S&S oil pump & cam plate for 2017-up Oil Cooled M8 engines, part # 310-0998.
Cam plate, assembly lube, and hydraulic tensioner block off plate (for use with gear drive cam)
Oil pump, assembly lube, orings, & hardware
In typical S&S fashion the kit includes comprehensive instructions as well as a complete breakdown of the components including part numbers
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The following 12 users liked this post by fuelmoto:
betho61 (07-05-2018), Keithhu (07-02-2018), Lu (07-07-2018), MotoJockey (07-02-2018), MTBIG G (07-06-2018), Northernproducer (07-03-2018), RinTin (07-03-2018), RJ111 (07-02-2018), South107 (03-10-2020), TomcatCV62 (07-02-2018), Tony P (07-02-2018), vtwinbmx (07-03-2018) and 7 others liked this post. (Show less...)
Top Answer
07-06-2018, 09:18 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,854 Likes on 1,001 Posts
Originally Posted by MotoJockey
Could someone be kind enough to explain the "Dual Scavenger" pick up system on this S&S set up that I her about that make it better than the Fueling set up? It's probably apparent to most, but I'm not so familiar with that aspect of these two pumps. TIA.........
The stock pump has two scavenging pickups, one for the cam case and one for the sump in the crankcase. It only has one scavenging gerotor which is the pump pulling on both pickups. So if the cam case gets pumped dry the pump will suck air on that side which can cause it to lose prime on the crankcase side which will result in sumping. Try putting two soda straws in your mouth, one shorter than the other. When the liquid gets below the short straw it will be harder or impossible to suck liquid through the other straw as long as you are pulling through both.
The S&S pump has a gerotor or pump for each pickup which makes it more unlikely the sump side will lose its prime. The money invested in it when doing any upgrades or even if it is your only upgrade is well spent in my opinion.
On the TwinCam they managed to counter this by making the sump pickup longer and smaller which also helped counter the variances in crankcase pressure caused by the pistons going up and down. The M8 just has a big hole on the right case where the oil pump connects. Harley has tried making the oil pump pickup smaller, whether that is working I can't say. Also, that's why if you idle it on the side stand there may be some extra oil collect in the sump. The S&S won't keep that from happening, but it should clear it soon after you stand the bike up straight.
Old 07-02-2018, 11:34 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Here are some images of the cam plate
front side of cam plate, note numbers for bolt install & torque sequence
back side of cam plate
note removeable plugs which allow cleaning of plate
cam plate shown with replaceable "wear plate" in place
South107 (03-03-2020)
Old 07-02-2018, 11:49 AM
jammerx's Avatar
jammerx
jammerx is offline
Very cool! Whats the difference between the water cooled and the oil cooled version?
Old 07-02-2018, 11:52 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
disassembled oil pump, note cleanable/replacable screen
oil pump, note pressure relief valve
The following 3 users liked this post by fuelmoto:
Max Headflow (07-03-2018), MTBIG G (07-06-2018), South107 (03-03-2020)
Old 07-02-2018, 01:41 PM
SavageChopper's Avatar
SavageChopper
SavageChopper is offline
Jamie,
The instructions say to disassemble and clean the oil pump, which I assume includes the oil pressure relief valve. Is there a certain "stock" setting when putting that back together? I had emailed S&S support, but haven't gotten a response.
Old 07-02-2018, 02:04 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Originally Posted by SavageChopper
Jamie,
The instructions do state to disassemble and clean the new oil pump, we are primarily looking for any debris or chips that may be present. The pump in this example was immaculate. As far as the pressure relief valve we are leaving it in the same state S&S sets them up for this initial install.
Old 07-02-2018, 02:17 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
In preparation for the oil pump & cam plate we've removed the exhaust system and so we have a little extra room the air cleaner snorkel on this bike
Cam cover removed, engine turned to TDC and dots aligned
Cam chain tensioner, cam chain & sprockets removed
Old 07-02-2018, 03:37 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 9,375 Likes on 4,783 Posts
cool stuff..is this to remediate a perceived or identified problem with the OEM pump, or just a customer's request or you guys doing it just for the heck of it to gain experience with these new ones? also, how many miles on the 2017? curious because the chain shoe looks great
Old 07-02-2018, 04:43 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
This is a customers bike that is running our FM 120" kit, looking to use upgraded components. I'll have to check mileage. Motor is together and I will update the thread with more info tomorrow.
mjwebb (07-02-2018), MotoJockey (07-02-2018), redtwin (07-02-2018)
Old 07-02-2018, 05:00 PM
Big Twi$t's Avatar
Big Twi$t
Big Twi$t is offline
What exhaust is this customer running on that 120"?
Quick Reply: Installation of S&S M8 cam plate & pump
