Headers opinion
Old 06-22-2018 | 04:24 PM
$tonecold's Avatar
$tonecold
Received 1,857 Likes on 1,003 Posts
Originally Posted by Gridhound
Thanks for the Dyno info. Did decide to go with tormentor exhaust. Just wanted to lose the cat hopefully help with the heat. Hoping sound is better. Long as I don't loose performance I'm ok.
Cycle Solutions has a pretty good price on that pipe, $539 and free shipping. It's probably as good a choice as any and the price is decent. I may have gone that way if I was in the market.
Old 06-22-2018 | 05:19 PM
Quik's Avatar
Quik
Received 2,577 Likes on 1,527 Posts
Originally Posted by Prot
Here is a combination I like. RCX Tormentor headers with S&S MK45 Mufflers. To me, this starts to get back to a more familiar sound. Listen to it with good headphones instead of crappy tablet, phone, or cheap computer speakers.
https://youtu.be/290GpJw3UZo
This shows how how they are made and why they work well.
http://www.rccomponents.com/rcxhaust...or-headers.htm
Don't forget that bike has a S+S 465 cam in it.
Old 06-22-2018 | 06:06 PM
cmashark's Avatar
cmashark
Originally Posted by $tonecold
One thing you may want to look at is what you will get for your money and is it worth what you're spending.
Here is a dyno sheet for a 107, TTS 100 cam and Fullsac header.
Now here is a dyno sheet of a 107, TTS 100 cam and the stock header decatted.
As you can see by 2100 rpm the bikes were making the same amount of torque and pretty much had identical output from then on. The Fullsac did make a difference in torque below 2100 rpm, but is that worth $700 to you. The Fullsac header is probably as good a header as any offered, so I wouldn't think the results would be much different with any 2-1-2 that you want to compare. Granted, it was not the same bike or the same dyno so you can take it for what it is worth. I personally don't think that the aftermarket headers make much difference until you get into some bigger motors. So you can ask others if they felt a lot of difference in their bikes performance and they may say yes, but is the pipe the only change they made? Just something to think about.
Eh, that’s almost an oranges and orangutans comparison. 2 different dyno, I don’t know what mufflers are on the second bike, what air cleaners, run conditions... I absolutely agree about the header vs decatted stock. If you can’t weld (or have access to someone who can), Fulsac, Fuel Moto, ect are great options for all stages. IMHO, I wouldn’t half *** it by trying to punch the cat out through the back of the pipe.
so, not a whole hearted disagreement, just a different view from another vantage point.
Old 06-22-2018 | 07:11 PM
$tonecold's Avatar
$tonecold
Sorry, both bikes are running stock cans with Fullsac cores, the stock decatted header was running 2” cores. I think it is interesting how close the results are between the bikes.
You don’t need a welder to remove the cat, just a long drill bit. Takes about 30 minutes.
cmashark (06-22-2018)
Old 06-23-2018 | 09:01 PM
Jackeyboi's Avatar
Jackeyboi
Stage I
Default Cobra Headers
Originally Posted by RK12
Have cobra headers on mine with 114 kit. Much louder and the cheapest at 425 ish. Don’t like the sound of 2-1 but make power.
I have the 107. Going with the Cobra Headers and NH Mufflers. What Tuner did you use?
Old 06-28-2018 | 09:09 AM
jerseyjeff62's Avatar
jerseyjeff62
V&H Dresser Dual header
V&H dresser duals for 2017 m-8 .these are a true dual system 2 pipes no bypass. i installed them on mine all V&H did was put a bigger end on the front cylinder pipe to accept the muffler.
Old 06-28-2018 | 09:19 AM
Clutched's Avatar
Clutched
I have Rinehart Slimline Duals,Quality Fit An Finish,Dynoed with Power Vision Tuner Runs Great!
Old 03-07-2020 | 05:54 AM
Misthios's Avatar
Misthios
Have you got a Dyno sheet for that mean machine?
Check6
Exhaust System Topics
07-12-2016 06:21 AM
Tn.Heritage
10-17-2012 01:15 PM
Road-King-Bob
09-12-2012 09:54 AM
mechmatt
12-16-2010 08:17 AM
Curtis629
08-24-2009 04:29 PM
Quick Reply: Headers opinion
