clutch questions 2017
So I have searched for a few hours on an issue I had this morning. I pulled the bike out to go to work (bike is always in neutral in garage) parked it in the driveway and put on my gear. I get on the bike that is running, pull in the clutch and put it in gear. The bike shuts off and I let go of the clutch lever. I pull it in and it goes right to the bar with no resistance. I say that master cylinder isn't working, I don't know how this system works because its my first Harley with this type of setup. What is on the other end of this setup? I just turned 15K on the bike. Is there any issues with this setup? The bike has been fine, didn't have any thing going on before this.
2017 flhtkl, 15k miles no add ons.
What do you think?
What do you think?
ok, same as some of my other bikes not in my sig.
So------ I get home ready to pull out the trailer and guess what, clutch is back and seems to be fine????? So I take it out for a ride and its still good. I went and filled up and still working, so I ride to the dealer to let them make a call as to what is next. I figured they would say can't duplicate the problem so keep riding it till it happens again. I pull in and the dealer says they want to check the moisture in the clutch fluid, hmmm sounds like they have seen this before. I'm going to take it back to the dealer after my better half gets home, don't have to take the trailer out.
Has anyone been in this spot?
I just installed the ‘17 model master and slave cylinders on my 2015 RGS and I noticed that the manual says that the DOT4 fluid should not be used out of a brand new container that is over a year old or an opened container that is more than a week old from initial opening. I guess it is very susceptible to absorbing moisture. The fluid I had had been open two weeks, but since it was Arizona I figured the humidity was low enough to get an extra week out of it. So if you have the dealer service your bike and they’re not aware of this they may be adding fluid that has been open for more than a week and in the process adding moisture to your system.
