S&S Oil Pump and Cam Plate Two Weeks Out
Old 08-02-2018, 02:58 PM
STRADALE's Avatar
STRADALE
STRADALE is offline
Originally Posted by stixvrad
So what are the chances HD will reimburse owners who had to go outside the family to solve their problem? I wont hold my breath.
Not a chance right but what happens to the 2017 & 2018 bikes if they actually manage to fix the fluid transfer and or the sumping in 2019’s inside the “family”? If it’s a possible parts swap to fix the 17’s & 18’s will they reimburse owners to make the change to the 2019’s parts?
Even more concerning is what about customers who aren’t even aware of sumping if their bike comes out if warranty & sump? W/ the MoCo knowing the issues exist & they’ve made changes to prevent it, are they still really going to charge customers for major engine work repairs or a new motor if necessary?
I say no & yes.
Gonna be interesting. We we live in interesting times, eh?
stixvrad (08-28-2018)
  #122
Old 08-02-2018, 05:30 PM
purpledeuce's Avatar
purpledeuce
purpledeuce is offline
No way the moco will make someone right out of warranty. They’ll say it wasn’t a common problem and only affected “a few” models
  #123
Old 08-02-2018, 05:47 PM
Heatwave's Avatar
Heatwave
Heatwave is offline
Member
Received 1,079 Likes on 639 Posts
You’re kidding ...right? The MoCo most definitely will NEVER cover the cost of installIng an aftermarket drivetrain component on a bike covered by the factory warranty. More importantly, the moment that the MoCo becomes aware that a Fueling or S&S oil pump has been installed in a bike under the factory warranty, you can absolutely be assured that the drivetrain warranty will immediately be voided for the duration of the remaining factory warranty and for the entire duration of any ESP, if there is one.
GUARANTEED. May not matter to those doing an aftermarket oil pump install but no one should go into the installation of a 3rd party drivetrain component wihout being full aware that the HD factory warranty and ESP on the drivetrain will most definitely be voided.
  #124
Old 08-03-2018, 05:44 AM
martin10's Avatar
martin10
martin10 is offline
So S&S has already modified their oil pump? Anyone know what they changed?
  #125
Old 08-28-2018, 07:38 AM
psoff's Avatar
psoff
psoff is offline
I received an email from S&S stating they will resume shipping their Oil Pumps Sept 1st.
  #126
Old 08-28-2018, 01:55 PM
MTBIG G's Avatar
MTBIG G
MTBIG G is online now
I have the exact same question.
  #127
Old 09-22-2018, 08:52 AM
masterblaster's Avatar
masterblaster
masterblaster is offline
do you have to remove the cam to replace this pump?
  #128
Old 09-22-2018, 09:26 AM
purpledeuce
yes, the pump is behind the plate
  #129
Old 09-22-2018, 11:04 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,851 Likes on 998 Posts
This is what Jamie at FuelMoto says:
“Stock cam plate & pump removed. Note cam, lifters & pushrods are in place. You do not need to remove them, this bike already has an upgraded cam bearing & components.
I don’t always agree with Jamie, but I imagine he has done this enough with good results to make this recommendation. Besides, a picture is worth a thousand words.
That said, you need to note that he says that the bike already has upgraded cam bearing and components. That probably means lifters and pushrods. I would say it depends on how far you want to go and what you are able to spend. If you don’t have the tools to change the cam bearing then you will probably be better off not pulling the cam.
He also doesn’t say whether the pressure on the cam has been relieved by collapsing the pushrods. If you have adjustable pushrods in place that would be a good step to take, I would anyway.
psyshack (09-22-2018)
  #130
Old 09-22-2018, 11:43 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,978 Likes on 4,045 Posts
That is an old EVO / shovel / pan trick. You have to get the cam in the right position where the load is removed from the valve springs..
Bumpandrun (09-25-2018)
Quick Reply: S&S Oil Pump and Cam Plate Two Weeks Out
